Unified Device Category for Authentication USB Storage Devices with Independent Access Control
Endpoint Protector Client
A dedicated “Authentication USB Device” category that consolidates USB storage and card reader recognition for authentication tokens into a single controllable device type is needed, so a consistent and effective access policy can be configured, including the ability to block user authentication.
EPP agent currently detects USB authentication tokens as two separate device types: USB Storage Device and Card Reader. Because the authentication function spans both device classifications, a user’s authentication cannot be blocked regardless of how the rights are set (Allow/ Deny Access) for either device type individually.
For ease of management, a single unified category that encompasses the full behavior of these authentication USB devices would be needed. This would allow admins to manage one entry rather than maintaining parallel rights across two separate device types (rights that, as it stands, do not achieve the intended result).
This unified category would also need to include the ability to block authentication entirely. Whether this is implemented through the existing “Deny Access” right applied at the category level, or through a dedicated third control option that is determined to be more technically appropriate. What matters is that the control is effective, meaning that when admins configure a block, the user is fully prevented from authenticating via the device.
At the moment, no reliable workaround is available within EPP. Applying “Deny Access” right to both USB Storage Device and Card Reader categories simultaneously has not been sufficient, as authentication remains functional regardless.
Hi Oana,
Thank you for the detailed write-up - the problem statement is clear and the consolidation approach makes sense from a management perspective.
This is on our radar but I want to be upfront - the request is technically complex. I’m not going to go much into details but USB authentication tokens typically expose multiple interfaces to the OS at the same time, which is what makes current per-category controls insufficient for this use case. Addressing it properly (both the unified classification and reliable enforcement) requires careful work on the client side before the server-side policy controls can be meaningful.
I have logged it and will need to assess the scope and then set its place on our backlog in the near future I’ll follow up here as things progress.
