Add a device type by IDs to block categories of devices outside the ‘usual’ device types included
I have a number of display/signage machines, and I’d like to permit StreamDecks (they’re used to control software on the machines)
Rather than ask Netwrix to write a ‘StreamDeck’ device type, I’m advocating the ability to create additional device types to accommodate all sorts of USB devices that aren’t managed by EPP, and that fall outside of the usual ‘corporate USB’ gadgets - A specific wireless body camera, a scanner, a USB barcode reader, streamdecks, USB audio DAC, for example.
Currently, I have to use a windows GPO to allow installation of these devices, rather than using EPP.
Hello Spencer,
Thank you for reaching out to us!
Please note that we are currently checking this request internally, and will get back to you with a response in the shortest time possible.
Until then, we thank you for the patience.
Regards,
Simona
Hi Spencer,
We wanted to share an update with you: your request is considered for comprehensive technical analysis. Once we’ve completed this process, we will keep you informed about the status of your item.
While we’re eager to address your request, our current commitments mean we won’t be able to tackle it in the immediate future. Thank you for your understanding and patience as we work through our planned priorities.
Regards,
Simona
Hello Spencer,
As an update, your item is still under review, and we will update you as soon as the investigation is complete. This may take some time as we navigate and handle our full high-priority items roadmap.
Thank you for your understanding.
Kind Regards,
Simona
