Create New Device Type for Scanners
Add “Scanners” as a new, predefined Device Type in the EPP Server under the Device Control section.
Currently, scanners are not recognized as a distinct Device Type within the EPP Server’s Device Control module, which makes managing them across an organization cumbersome. Administrators must manually identify and add scanner devices on a case-by-case basis, leading to inefficiencies and inconsistent enforcement of security policies. By introducing a dedicated “Scanners” device category, Endpoint Protector would allow for centralized, consistent management and rights assignment for all scanner hardware. This streamlines policy creation and improves the overall security posture by ensuring that scanner usage is monitored and controlled just like USBs, printers, or external drives.
We manually identify scanner devices and add them individually to the policy list, which is time-consuming and difficult to scale in larger environments. This manual process also increases the risk of misconfiguration or oversight, potentially allowing unauthorized scanning of sensitive documents without proper control or audit visibility.
Hi Zoran,
Thank you for submitting this idea!
We are pleased to inform you that this feature request is valid and is actively under our consideration.
Our Development Team is currently engaged in a thorough analysis of the technical possibilities for implementing this solution. In the meantime, we appreciate your patience during this process and invite you to stay informed about future updates.
Once a conclusion has been reached, we will promptly notify you.
Kind Regards,
Simona
