Request to add FileZilla to DPI applications
Currently, FileZilla is not included in the DPI application list.
As a result, it is not possible to block or detect file transfers based on specific IP addresses or URLs when using FileZilla.
This limitation forces administrators to either fully allow or fully block FileZilla, reducing the flexibility and effectiveness of DPI policies.
If FileZilla is added as a DPI application, administrators would be able to apply more granular controls, such as blocking or monitoring file transfers to specific IPs or URLs.
This would allow DPI functionality to be used more effectively while maintaining necessary access for legitimate use cases.
Currently, FileZilla is being used either in full monitoring mode or fully blocked, as granular control is not available.
Hello,
Thank you for reaching out to us!
I’m happy to announce that this enhancement is already on our radar — our development team is exploring the possibility of adding visibility and DPI coverage for FileZilla, which will address your use case as well.
Please note that the investigation will require some time. Thank you for your patience!
Rest assured, once the investigation is complete, we’ll share an update here to keep you posted on the progress.
Kind Regards,
Simona
