How redaction plan works?
Hello,
In a Data Classification workflow, it is possible to integrate a “redaction plan.” If I’m not mistaken, the redaction plan allows replacing terms/words with other elements in a document.
I have never been able to make it work.
Has anyone here successfully implemented it? If so, how did you get it to work?
Or am I completely wrong? In that case, what is the purpose of the redaction plan?
Hi Romain, yes, that’s how it’s supposed to work. In the most basic scenario, you are supposed to be able to choose a word or a regex, e.g. card number, and replace it with something like [redacted].
By not being able to get it to work do you mean you couldn’t complete the configuration, or it errors, or anything else?
I also checked our documentation and I have to admit it is not very specific Redaction
@Romain.Fauvet the team has helped me find this training: Rise 360
Please let me know if you can access it, you should be able to. It goes into a lot more deatai on what exactly needs to be done.
Hey @Romain.Fauvet,
Did Dmitry’s suggestions answer your questions?
Sorry, but no.
If I could just have a video showing a file with a specific word being removed or replaced with a redaction plan, I would be the happiest man on earth!
No worries, we haven’t given up yet! I’m sure the team will get back to you on Monday!
Hello @Romain.Fauvet
When you configured the redaction plan, did you also configure a migration workflow?
You can think of the redaction plan as the “template” used and the workflow is what applies the template to a document.
Once a redaction plan is created (as seen is the Rise360 content @dimav shared) you should see this:
Are you erroring out along the way? Or does the workflow error when it runs? We might need some more information to determine which direction we should go.
Of course, I did it.
If you have time, please send me a screen recording showing how you configure it, along with the result.
For example, I’ve created five files (Word, PDF, TXT, Excel, PNG) where I want the word “Romain” to be replaced with “Martin.”
In the workflow, the file go to the destination folder, but the word “Romain” is still there…
How can such a major feature from NDC be so hard to configure and so poorly documented?
Hi @Romain.Fauvet
Absolutely! Here is a video showing the end-to-end.
To add a little colour on what I show here:
  1. Taxonomy - redactions work on the basis of replacing extracted regex values with the redaction text, so the clue type must be “Regex” for the redaction to work.
  2. Redaction Plan - on a basic level for the test you’ve described you would only need to set the plan name and replacement text.
  3. Workflow - on a basic level the only real difference from a normal migration is needing to set the redaction plan.
  4. Files - text correctly shows the value identified by the regex rule.
  5. Destination - files are not there yet pending the execution of the workflow.
  6. Reclassify - I restart the services here to kick the process off a little quicker.
  7. Results - files are created with the desired redaction applied.
I hope that this helps!
I owe you a beer! I did it—I think the issue was the text format. I was mainly using Standard.
Hi, Michael,
I’ve create a redaction test. it should replace specific regex ( french ssn) by a text.
But i got error :
Unable to redact document - migration skipped. Please see the Event logs for more details.
my doc is :
Taxonomie is ;
But every time , i got a failed ,
Can I get some help ?
Hi @Romain.Fauvet
The full details for the failure of the redaction can be found in the Window Event Viewer. I would recommend reviewing this in the first instance and if you have any concerns then please raise a support request providing an export of the event logs for investigation.
Thanks
Mike
