Simple Role Rules Management: Choosing Dimensions
What is a one-sentence summary of your feature request?
Managing simple role rules: choosing dimensions
On the simple role rules screen, it should be possible to configure the dimension columns.
There are currently 5 columns, which are displayed according to the order in which the dimensions were created in the configuration. These dimensions are not necessarily the ones used most often.
We’d like to be able to choose the dimensions.
You have to open each rule to see which criteria have been selected.
