Full display of an assigned role
Display Roles like other search fields in assigned roles.
Hello,
in the “Assigned Roles” tab, the filter on the role truncates the name, which makes searching for a role very difficult. This tab is very useful to us, but it is not usable as it stands.
Browse through the rows one by one with the mouse.
Hi @ChristopheCoudert
Thanks for your submission! I can’t see the entire screen here, but did you filter by category first? the reason that this field is smaller is because it should only need to show the name of the role, not the entire name with categories. Does adding a filter help you see the entire name?
Thanks for your feedback!
Kate
Hi @kate.flemo
Thanks for coming back to me.
Even when I select a category the role name is too short unfortunaly.
Renaming all our roles is not possible.
Thank you for your help.
Christophe.
Thanks for your reply , @ChristopheCoudert . We will put this on the roadmap to improve.
I’ll update this thread as needed
Make it possible to manually adjust the width of the filter fields in the “Assigned Roles” screen
A client has requested the ability to manually adjust the width of the filter fields in the “Assigned Roles” screen because the names of their roles are sometimes a bit long. As a result, it is currently impossible for the client to select the desired role.
No workaround
Hey @raphael,
I’m merging your idea with this topic to consolidate feedback and updates :slight_smile:
