Parametric role request with manual selection of parameters
Parametric role manual request : Limit the dimension values that are referenced in navigation rules
When a user request a parametric role and choose their own parameter values, the user is presented with all available dimension values.
However, many of dimension values may not result in the granting of any resources (e.g navigation rules) in a target system. This can be confusing and inefficient for the user.
A key improvement would be to allow at trole level (as we are currently able to specify if the parameters are mandatory or not) to filter the dimension values presented to the user, so they only see those that actually provide access to resources within a target system.
No technical workaround. Change management and role request review.
Please let me know if it already technically possible.
hi @Cedric thanks for your post!
I will check with the team asap if this is possible already to configure, and I’ll update you here.
After talking with the team, this feature was implemented in the past, but with negative results, so it was since removed. For now, I will move it to not planned.
Thank you for the feedback. May I know what were the negative results ?
Hi @Cedric My apologies, I replied to the wrong thread on this one. :woman_facepalming:This one I’ll move to “under review” and I’ll reply to in the correct thread for this idea request: Hierarchical access control filter - Identity Manager / Ideas - Netwrix Community
