Improvement "Rôles assignés" / "assigned-roles"
What is a one-sentence summary of your feature request?
Improvement to “Assigned Roles” / “assigned-roles”
We require several improvements regarding the “Assigned Roles” functionality:
1 - Make comments mandatory when removing a role (comments are already required for additions, but not for removals, yet we need them to track the rationale for such removals).
2 - When adding a role, allow searching for a beneficiary using a “Contains” mode instead of “Starts With” (it is more ergonomic to search for a person by their name, as our current internalDisplayName includes a prefix).
3 - Enable traceability of permissions at the role level rather than at the user level.
4 - Allow more granular AccessControlRules on scopes: Read, Modify, Add, Remove.
We need to restrict application managers to only viewing and removing permissions, while additions are managed by managers.
Currently, we cannot make this functionality available to application managers as it does not fully meet our needs.
Without these enhancements, we will have to pursue a custom development solution.
Hi @olivier.moreau thanks for your submission. These are all great ideas to improve the use of this page. Can you please explain more what you are looking for with #3?
Thanks,
Kate
Hello,
During my tests, I was expecting to see in the Workflow monitoring screen the add/update/remove request made by this process.
To track this change in permissions, I have to go through the user’s permission cart screen.
Would it be possible to centralize these actions in the Workflow monitoring screen?
Or to have a screen that allows these changes to be tracked? (administrator/Governance view)
We are working on the following improvements that you requested:
  1. add permissions to each action to be performed in the page.
  2. make a comment mandatory or optional when removing a role
We are targeting these improvements to be released by the end of the year.
We are still considering how to show the changes in a more centralized dashboard as you mentioned. Today this is not planned for a future release.
