Auditor Bug Fix List
:pushpin: Looking for a bug fix list for all versions of Auditor?
All bug fixes will automatically be added here!
10.9 Updates
Netwrix Auditor 10.9 Update 1 (10.9.16400)
August 27, 2026
Description Escalation # Case # Bug #
Memory leak in the audit archive service that could leave the datasource manager stuck uninitialized after high load, causing the Web API to stop returning new Activity Records (as seen with SIEM integrations). 419119 463696 439978
SQL Server State-in-Time collection failing when databases contain external (Entra ID) users or groups, which previously caused snapshot upload errors and incomplete reports after cross-domain migrations or in-place upgrades. 440809 474524 443994
Azure AD/Entra ID State-in-Time snapshot uploads failing due to duplicate directory role membership records returned by the Microsoft Graph API, which previously caused role-membership reports like Global Administrators to return no data. 441316 477823 442693
Report generation failing with an “Inconsistent Report Server URL” error when the SSRS Report Server URL was configured with an explicit port 443, which previously required removing the port number as a workaround. 442161 479410 371525
File Storage Auditor collection stopping entirely after a snapshot became corrupted on Unity/EMC storage targets, which previously required manually clearing the snapshot folder to resume data collection. 441016 478630 441087
Netwrix Auditor Logs Collection Service crashing repeatedly when a Nutanix Files monitoring plan is active, caused by a syslog TCP reactor invoking a callback on an already-destroyed collector object. 447641 482867 N/A
Mailbox audit collection fails with ArgumentNullException in SerializationDataPsMailboxParser (System.Guid..ctor) 450457 483208 450861
Netwrix Auditor for Azure Files reports user actions as Entra Object ID (GUID) instead of UPN in “Who” column. 445513, 445518 475884, 482070 445664
Exchange Online throws “Unable to collect mailbox permissions due to the following error: Object reference not set to an instance of an object.” 444558 481540 444947
Insufficient space for TempDB and execution plan regression after bulk operations due to stale statistics on Conf* tables. 444008 477732 450299
Fixed SSRS report generation continuing to run on the server after a user navigated away or re-generated a report, which previously wasted server resources on abandoned report jobs. N/A N/A 114059
Fixed User Activity Monitoring incorrectly treating two different computers as the same monitored target when IP addresses were reassigned within a configured IP range, which previously caused monitoring data to merge under one identity. N/A N/A 344712
Fixed SharePoint Online State-in-Time statistics collection failing after Microsoft retired the legacy MSOnline API, which previously caused an access-denied error during snapshot collection. N/A N/A 391452
Fixed SharePoint Online permission reports failing to mark externally shared Entra ID accounts as External, which previously caused those users to appear in reports even when external sharing was disabled for the tenant or site. N/A N/A 406505
Netwrix Auditor 10.9 Released: State-in-Time reporting and risk assessment for Azure Files
June 30, 2026
Fixed incorrect hostname resolution in User Activity Video Recording caused by extra entries in the local hosts file — the Workstation field in Activity Records now shows the actual computer name instead of vmware-plugin. 347095 415506 357515
Fixed missing Workstation field data in Activity Records collected from Isilon data sources — the FSA collector now correctly populates it from Isilon audit logs. 397371 452201 N/A
Fixed a configuration validation bug where the FSA Isilon collector ignored the configured access zone name, triggering false “unconfigured audit settings” errors on non-default zones. 420411 471947 422507
Fixed SQL deadlocks that occurred when running SSRS-based reports (e.g. Failed Activity) due to a lock conflict between long-running report queries and the ManagementService background update routine. 420838 472333 424595
Fixed a silent failure on Windows Server 2012 R2 where clicking Export in predefined SSRS reports did nothing — caused by incorrect browser environment detection that prevented the save dialog from opening. 433194 476035 433426
Fixed an issue where agents were still deployed to target computers even when the User Activity Video Recording data source was disabled in a Monitoring Plan. N/A N/A 370772
Fixed a broken footer link in SSRS reports — clicking the Netwrix link no longer shows an “Inconsistent Reports Server URL” error. N/A N/A 384483
Fixed alert filters with detail-level conditions not firing for Group Policy, owner, and non-owner mailbox activities in Exchange Online, which caused missed alert notifications. N/A N/A 389446
Fixed a suboptimal join order in audit database views that caused unnecessary performance overhead when running reports covering Group Policy or Exchange mailbox activities. N/A N/A 402917
Fixed an unhandled exception crash in the Exchange Online mailbox owner audit collector when required application permissions are missing — it now logs a clear error and continues gracefully. N/A N/A 425689
Fixed incorrect report type classification — State-in-Time reports for Entra ID, Exchange Online, and SharePoint Online are now correctly displayed as State-in-Time reports in the Netwrix Auditor console. N/A N/A 425861
10.8 Updates
Netwrix Auditor 10.8 Update 10 (10.8.15833)
June 2, 2026
Fixed SharePoint Online activity reporting so the actual user is now correctly displayed in the “Who” field instead of “OneDrive SyncEngine”. 435572 477160 N/A
Resolved an issue where SharePoint Online State-in-Time data collection fails for site collections that have become inaccessible due to unlicensed accounts. 435007 476851 N/A
Corrected Exchange Online mailbox permission snapshot so “Deny” permissions are no longer recorded as “Allow” in State-in-Time reports. N/A N/A 435671
Netwrix Auditor 10.8 Update 9 (10.8.15830)
May 13, 2026
Improved reliability of Exchange Online auditing by resolving a type conversion issue that could interrupt data collection. 433510 476267 N/A
Optimized memory handling for Netwrix Auditor services to reduce excessive RAM consumption by lsass.exe. 416208 469524 N/A
Enhanced reporting accuracy for Entra ID group membership changes to correctly display added and removed users. 425779 474387 N/A
Resolved an issue that could cause the SQL Server Audit Service monitoring plan to remain indefinitely in a “Working” state. 423438 473349 N/A
Fixed manager notification delivery so email alerts are now sent correctly by Inactive User Tracker. N/A N/A 415440
Improved readability of Entra ID membership change events by displaying user UPNs instead of GUID values when changes are made through Microsoft Graph API. N/A N/A 411171
Corrected handling of report server URLs specified as IP addresses to ensure they are properly stored in Internet Settings. N/A N/A 409728
Improved report server URL management so FQDN values are now preserved correctly in Internet Settings, even when the same server was previously saved using a different format. N/A N/A 409572
Netwrix Auditor Update 8 (10.8. 15813)
April 2, 2026
Employee attributes are blank in Active Directory State-in-Time reports after an upgrade. 419942 471763 N/A
Support MSOLEDB providers instead SQL Server 2012 Native Client fot encrypted connections. 411698 466554 N/A
Meraki Dashboard auditing does not capture all content filtering (web traffic) logs. 398690 453607 N/A
Password Expiration Notifier sends emails to the managers that are not specified in the user’s properties. 421173, 420376 472414, 471910 N/A
Agent for User Activity Video Reporter does not write logs. N/A N/A 420402
Netwrix Auditor Update 7 (10.8.15804): Streamlined permissions requirement for Exchange online auditing and bug fixes
March 5, 2026
Azure Files Auditing returns false positive Activity Reports 409923 463107
User Activity Video Recording displays no new data after upgrading to 10.8.15792.0 419084, 419122 471022, 471072
Netwrix Auditor 10.8 Update 6 (10.8.15792): Rebranded UI and minor improvements
February 5, 2026
Description Bug #
Added the ability to edit defined objects to exclude for the Active Directory Activities collector in the Netwrix Auditor user interface 390456
Netwrix Auditor 10.8 Update 5 (10.8.15173) Released
January 29, 2026
Description Case # Escalation # Bug #
WorkingHours filter does not function as expected 462953 409741 N/A
Cannot collect Entra ID snapshot due to the following error: The remote server returned an error: (403) Forbidden. Request Authorization failed 467404 412736 N/A
Exchange Activity Records with details “Features Approved changed to…” are overwhelming Search 463881 410518 N/A
SharePoint Online SharedLinks are not being collected for some type of Site Collections N/A N/A 406123, 409657
Netwrix Auditor 10.8 Update 4 (10.8.15119) Released
December 11, 2025
Excluding events in Health Log by Event ID does not work when a Monitoring Plan is included 459240 405535
MS Teams auditing only getting partial audit data 460981 407697
Netwrix Auditor Version 10.8 Update 3 (10.8.15089) Released
November 6, 2025
Exchange Online search issue whilst filtering by Details 455715 401317
File Storage Auditing service crash in Access Reviews processing with recursion in group membership 458490, 458999 404426, 405325
Access denied in Active Directory collections using custom credentials for shared Long Term Archive folder 456511 402025
Azure Files shows a lot of collected data who=system in Search 457503 403310
Active Directory Auditing reports attribute changes made and reverted when they were not reverted 439678 379632
“Does not contain” filter for Details has been improved N/A N/A
Netwrix Auditor Version 10.8 Update 2 (10.8.15066) Released
September 25, 2025
| Description | Case # | Escalation # |
| File Server - NetApp error message: “This operation is supported only when you are connected to the server.” | 442774 | 383885 |
| Exchange Online State in Time Collection issues in GCC tenants with China tenants | 442668 | 383794 |
| User Activity out of Memory issue | 446373 | 388612 |
| Bugfixing in Active Directory Restore Wizard | N/A | 383195, 383204, 378233 |
Netwrix Auditor Version 10.8. Update 1 (10.8.15036) Released
August 5, 2025
Unable to complete search due to a collation conflict. 450541 395448
Netwrix Auditor for SharePoint Online State-in-Time reports incorrectly calculate permissions for external users. 449385 393421
Netwrix Auditor Version 10.8 Released
July 1, 2025
Fault tolerance improvement in integration with Netwrix Data Classification 419364 357595
Add detection and removal of corruption in the HealthData buffer of the Windows Server Auditing working folder 413201 347000
Improved error reporting in the CallHome feature 443802 385073
Remnants of failed uninstallation information in Agents.xml prevent targets from being re-added to the auditing scope of User Activity Auditing 388568 344839
Access error occurs when using NPS integration in environments with multiple domain controllers 420343 358009, 358018, 358071
Duplicate items appear in the Monitored Computers tab of the User Activity Auditing data source 388568 127320
Windows process security context is used for browsing SSRS reports instead of the explicitly provided credentials in Netwrix Console 401299 339251
ConfigServer nodes are being accessed by the Data Collecting Account of Inactive User Tracker 400654 340091
AD Restore Wizard improvement: Prevent deletion of indirectly checked objects when restoring a constructed attribute 437805 379951
Synology, Nutanix, Qumulo, Unity: No change detected when permissions are modified on top-level share objects N/A 306133
10.7 Updates
Patch Version 10.7.13850 Released
June 26, 2025
Netwrix Auditor for VMware: Failed to process certain objects during State in Time collection. 429223 367490
Netwrix Auditor for Azure AD: Fixed high memory consumption issue. 440700, 442895 380595
Netwrix Auditor for Access Reviews: Unexpected memory consumption during file server data processing. 441364 381831
Netwrix Auditor for Inactive Users: Access Denied error when attempting to save a plan. 443519 384657
Alerts do not adjust to Daylight Saving Time (DST) changes. 381815
Patch Version 10.7.13822 Released
April 23, 2025
The following table contains a comprehensive list of updates and fixes released on April 24, 2025.
Netwrix Auditor for Windows Server Unable to detect audit policy settings for the server Ticket 440941 380872
Netwrix Auditor for Access Review webpage closed with error - block access Ticket 438749 N/A
Patch Version 10.7.13820 Released
April 17, 2025
The following table contains a comprehensive list of updates and fixes released on April 17, 2025.
Netwrix Auditor for Logon Activity: The audit policy data registry value has an unknown format N/A 382078
Netwrix Auditor for File Servers: The audit policy data registry value has an unknown format N/A 382022
Netwrix Auditor for Windows Server: Unable to detect audit policy settings for the server Ticket 440941 380872
Audit Configuration Assistant: The audit policy data registry value has an unknown format N/A 382151
Netwrix Auditor for Sharepoint Online: Unable to parse the FileDeleted event Ticket 440454 380338
Netwrix Auditor for VMware: failed to collect data for state-in-time snapshot Ticket 429223 367490
Patch Version 10.7.13813 Released
April 3, 2025
Description Case # Escalation / Bug #
Netwrix Auditor for File Servers returns licensing error even though Access Reviews is not configured Ticket 438897 Issue 378875
Netwrix Auditor for Exchange Online does not include some mailboxes in reports Ticket 435479 Issue 374939
Performance and stability improvements in the Migration Tool for Working Folder Ticket 428843 Issue 367013
Netwrix Auditor for Exchange Online reports unnecessary changes under NT SERVICE accounts N/A Bug 379153
Patch Version 10.7.13808 Released
March 4, 2025
  • Feature 289061: [Access Reviews] Allow choosing subfolders for review
  • Feature 362902: [Security] 2.3.7 Weak Assembly Control fix
  • Issue 376203 Ticket 436229 Misspelling in omitproplist.txt file
  • Issue 376182, 376332, 376726 Ticket 436211, 436372, 436761 NwUserActivitySvc failed to start when upgrading to 10.7
  • Issue 374354 Ticket 434846: [CoreServices] Netwrix Auditor Archive Service Windows crashes on failed AR upload
Minor Version 10.7 Released
June 25, 2024
See the Netwrix Auditor 10.7 Bug Fix List (184.0 KB) PDF for a list of bugs fixed in this version.
:double_exclamation_mark: The following versions may have limited or no support. Please see the Supported Version page for guidance.
10.6 Updates
Minor Version 10.6 Released
August 8, 2023
See the Netwrix Auditor v10.6 Bug Fix List PDF for a list of bugs fixed in this version.
