I need to configure my first monitoring plan for a Dell Powerscale NAS.
Netwrix version - 10.8
I followed the instructions for configuring the data source. i.e. copied the shell script over, and ran it on the NAS. But I’m having trouble with the creation of the monitoring plan.
I’m not sure what to put in for Name. I know the zone, and the OneFS URL, but I’m not sure of the File Share UNC path to audit logs, either.
Name (Specify Dell Isilon storage array) — enter the IP address or hostname used to access shares in your access zone. Auditor uses this to construct share paths and enumerate shares.
\\<System zone FQDN, NETBIOS, or IP>\netwrix_audit$\logs
Error 2003 has two likely causes in your case:
The Name field contains an address that cannot be reached over SMB or has no accessible shares
The Scope section has no shares configured — make sure either “All file shares” is selected, or at least one share is added under “Specific file shares”
