view all Group Policies applied on a particular endpoint, and vice versa, which endpoints have a specific GPO applied
As of this date, Netwrix Auditor does not provide the feature of mapping all Group Policies applied on a particular endpoint, and vice versa.
we are trying to make ways with manual/powershell scripting inspections of GPOs but its quite complex & unstable process, plus we need to put the data in a professional report, and obviously we only get the raw data or simple html/xml based report if we push the limits in manual hunting
Thanks for idea! Today, Netwrix Auditor focuses on changes auditing for Group Policy - e.g., who changed which GPO, when, from where, and the before/after values - and provides predefined reports and an Interactive Search for those changes. It does not currently inventory the Resultant Set of Policy (RSoP) per endpoint or provide a built-in “GPO ↔ endpoint” mapping view.
If your goal is to see “all GPOs applied to a specific endpoint” and, conversely, “which endpoints received a specific GPO/setting, my thoughts are about Netwrix Endpoint Policy Manager. https://netwrix.com/en/products/endpoint-policy-manager/
@jeremy.moskowitz can you please advise?
Hi; sorry for the delay in replying.
So, we have the Group Policy Compliance Reporter.
It’s job is to:
Have you design a TEST (series of policy settings within GPOs you want to CHECK for.)
QUERY online machines -or- have those machine “explain their current state” to a server.
VERIFY if those TEST policies ARE or ARE NOT on those endpoints.
Suggest you check out: Video Learning Center | Netwrix Product Documentation
And watch the 7 minute video then the Standalone Mode and Server mode videos.
Then if you LIKE IT, we can get you into trialing it.
Thanks !
