OTP workflow to be automated via a dedicated IT Helpdesk tool
Integrating the request and delivery of one time passwords/ offline temporary passwords (OTP) with ServiceNow by allowing these requests to be automatically routed through the organization’s helpdesk system would centralize communication, improve traceability, approval workflows, response times but also ensure constancy for users in what concerns computer-related support needs.
Currently a user can request access to a specific device from the Endpoint Protector client window by selecting the device, the duration, typing a justification and hitting the “Send Request” button (this request is delivered to the email address set for the Main Administrator although there is an option to define admins with EasyLock Administrator role). Once generated, the only built-in method for delivering the OTP to users is via email. While this works, it lacks visibility and transparency for the IT/ helpdesk teams managing these requests. Any alternative methods for handling or tracking access through OTPs - such as through internal ticketing - must be managed outside of Endpoint Protector, adding complexity and fragmentation.
Thank you for taking the time to share this request.
We’re pleased to let you know that ServiceNow Integration is already part of our strategic roadmap and is currently undergoing detailed technical evaluation. As we explore the most effective and reliable way to implement this functionality, including the OTP use case/workflow you described, we want to ensure all aspects are carefully considered to meet both performance and usability standards.
At this stage, we are not able to provide a specific timeline for delivery. However, please rest assured that this item is actively being tracked and prioritized as part of our ongoing development planning.
We genuinely appreciate your input and we’ll be sure to share updates as soon as they become available.
Thank you for reaching out with your question.
This project is currently scheduled to begin development in 2026. As we move forward and progress is made, we’ll be happy to share more detailed updates here.
I’m working with our company’s ServiceNow team and have been told that the basic auth config currently in NTM can’t be used for our implementation. I’m told that to integrate with our ServiceNow implementation, it needs to be an Oauth 2.0 supported as we need to make two API calls. First, to get a token and then doing the task via a second API call.
Will this type of authentication be added at some time?
After discussing with the team, we’re pleased to share that Oauth 2.0 support will also be considered, though it’s planned as a longer-term initiative. At this time, we don’t have an estimated timeline to provide for this. Any updates will be shared upon progress.
