SAML SSO with Keycloak returns HTTP 500 after fixing clock skew
Setup
  • Endpoint Protector virtual appliance on VMware ESXi
  • Keycloak as SAML 2.0 Identity Provider, configured via the Okta profile
  • Internal test environment
What happens
SSO login fails, and the failure mode changes depending on the appliance clock:
  • Appliance clock off by 1h42m: EPP shows the regular SSO error page (“There has been an issue with your Single Sign On Process”).
  • Appliance clock synchronised to the IdP (0 seconds difference): EPP returns “Oops! An Error Occurred - The server returned a 500 Internal Server Error”.
Both reproduced twice, each matching the state of the clock.
What I already checked
  • The clock skew is fixed. The default NTP server (pool.ntp.org) is not reachable from this network segment, so I replaced it with an internal NTP server under Appliance > Server Maintenance > Time Zone. Both clocks now match to the second, verified in UTC on both sides.
  • On the Keycloak side, a client session for the Endpoint Protector service is created on every attempt. So the IdP authenticates the user and issues the assertion - the failure happens inside EPP after the assertion is received.
  • Identity and attribute matching: four different configurations were tested earlier, all failed identically while the clock was still wrong.
Questions
  1. Has anyone seen a 500 on the SSO callback with a correctly synchronised clock?
  2. Where does the appliance log SAML processing errors when SSH access is not available?
Hi Fabian!
Thank you for reaching out and welcome to the Netwrix Community!
Please allow me to double check on the scenario you described and I will get back to you on this topic.
Super Thanks!!
Hi Fabian!
Apologies for the late reply on this.
After checking internally, given that the issue you raised will require further investigation, our advice for you is to open a Support ticket from the Support Portal, so out Support Team can take a closer look at the issue that you described.
