When trying to configure our SAML to use SecureAuth and I get to the test logout page it fails with an error 404. Upon investigating using the devtools in edge it is specifically for the page https://..org:6500/api/v1/token/GetLoginMethods. I am currently running 25.6.001 and have ran a repair to confirm with no luck… Any advice would be appreciated
Hi Andrew - can you please open a ticket with our Support team? Sounds like this is something they’ll need to investigate in your environment.
