Request to Add Claude AI Applications to Policy Exit Point
Hello, this is Seungwook.
I would like to request the addition of new applications to Policy Exit Point.
At the moment, we are unable to control or restrict AI applications like the following:
Could you please add these types of AI apps to the target list for our policies?
Thank you for your assistance,
Kind regards.
As we currently have no way to control it, we need to block the application from running.
You’re right to call out the difference here. Coverage for AI interactions is one thing, but having a dedicated application such as Claude available directly in Policy Exit Points is a more specific use case, especially for customers who want to control the desktop app itself rather than rely only on browser-based controls.
We’ve captured the request and will keep it under review as part of our medium-term planning for this area.
For now, blocking the application from running remains the practical workaround, as you mentioned.
We appreciate the feedback and the concrete example.
