Privilege Manager Registry Traverse Rule for Registry Values
Need a way to allow users access to a regsitry key while restricting certain values
We are attempting to give user access to manage their own startup applications in Settings-> Apps → Startup. By default, any machine-wide application requires users to be an admin to change it. We can enable users by a registry traverse rule to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved. The problem is that there are a few applications we don’t want users to be able to disable. So need a rule that can set those few registry values to remain with read-only access.
We do not currently have a way to enable users to manage startup applications. Without this feature, we will not be able to roll out a solution because there are some applications we can’t allow users to disable.
