Customer would like to have a new allow case in which it allows if the device is TD level 1+, but also allows if the TD level is detected as level 2 or 3 or 4 without trying to auto deploy easylock if it is, for example, a bitlocker device or some other encryption.
Customer has a mixed device environment between regular unencrypted USBs, software encrypted USBs, and some hardware encrypted USBs. They would like to block users from accessing unencrypted USBs, but would like to Allow access to encrypted devices that are at least level 1 encrypted with easylock auto deploy (TD level 1+), but will also allow for TD level 2, TD level 3, and TD level 4 without attempting to deploy easylock to them.
Going with this solution, it will allow the customer to set that for their whole environment encompassing all the devices they have.
Customer has to block software encrypted devices and only allow them on a as needed basis and setup a custom class for allowing hardware encrypted devices.
Thank you for sharing your idea with us!
We’ll make sure to record it on our side. Our team will need some time to carefully explore the possibilities of implementing it to best address your use case.
Once we’ve completed our investigation, we’ll share any updates here.
After completing our internal investigation on this use case, we confirmed that the following configuration should achieve the expected behavior:
You can select the TD1 level (not TD1+). In this configuration, EasyLock will not be applied to devices with TD2, TD3, or TD4 trust levels, provided that these levels are allowed.
Additionally, you may temporarily add TD1+ as an exception for devices that do not have EasyLock enabled. Once those devices are addressed, you can remove the exception and continue using the standard TD1 policy.
Based on our testing, this behavior works as expected. Therefore, could you please test this configuration on your side and share your feedback with us?
