Rule for "LMCompatibilityLevel LM & NTLM"
Allow certain rules to have configurable logic
Problem:
Split S-OldNTLM into two checks
Enhance action plan experience
The rule S-OldNtlm is designed to “ensure that the NTLMv1 and old LM protocols are banned.” However, this rule does not differentiate between sending NTLMv1 (Levels 0, 1, 2) and only accepting NTLMv1 (Levels 3 & 4).
While accepting NTLMv1 is not ideal, the major risk lies in sending NTLMv1 due to the potential for MITM (Man-In-The-Middle) attacks, relaying, and easy cracking.
Proposal:
Adding Action Plans in the consolidation view is something we should consider to unify the views. This will be added to the backlog for now, but it is definitely something we will look into.
We should split S-OldNTLM into two checks:
S-OldNTLM: Modify this to only identify enabled GPOs that send NTLMv1 (Levels 0, 1, 2).
S-OldNTLMDC: Create this to specifically target DCs that are not set to the recommended levels to reject LM and NTLMv1 (Levels below 5, with 5 being the most secure option).
Regarding Rule Logic Modification, this is not something we are actively pursuing at the moment. However, we can add it to the backlog. Additionally, we have an item on the backlog for custom rules via PowerShell to extend detection.
You can filter these domains in the “Consolidation” section:
Go to Dashboard
Navigate to Risk Score
Select Consolidation
Choose Password
Go to Security settings
Search for: LAN Manager authentication level
Unfortunately, it is not possible to create Action Plans or similar actions. I also attempted to modify the Rule S-OldNtlm, but there is no option to change its behavior.
Hi Brandon,
I know this was one that came from a customer who was not yet on the community and we wanted to get this visible but this is multiple ideas and already has my initial response (the proposal) in the text so not much to add from my end.
We already have an idea for the Action Plans enhancements so we will track that there.
I will create a new idea for you for the configurable rules enhancement to track the votes properly.
We can then keep this idea specifically for the LMCompatibilityLevel ideas for the splitting of the two checks.
Cheers!
