More dynamic Passphrase rule capabilities
Be able to have a more sophisticated way to allow passwords that are stronger, not just longer in the passphrase rule
The passphrase rule is fantastic but has some limitations for customers that want to get more sophisticated. For example, instead of just turning a rule off, it would be nice to have some on and some off so we could turn on some rules if passphrases are used. For example, passphrases must have spaces or hyphens but no other complexity.
Use a custom complexity rule and leave it on always.
Is it worth going so far as to assign a different policy based on length? This is the most flexible solution, but is potentially confusing to configure and use.
A compromise is to have the on/off feature that you mentioned above and two or three password length thresholds (currently only one). This is less flexible than different policies, but also less confusing.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
