Improve Max resolution in Netwrix Privilege Secure sessions
Improve Max resolution in Privilege Secure sessions so users can use 4K screens and more
Currently users are unable to go full screen on their privilege sessions when connecting from NPS if they are using large screens or higher resolution monitors.
users connect from RDP client using connection strings
Hi Sony,
Thanks for submitting this request!
We have asked one of our developers to research what the potential lift would be to add support for QHD and 4K resolution monitors. We will keep you posted with our findings.
- Dan
Hi Sony,
We are looking into allowing higher resolutions, but in the system settings → global settings page
If multi-monitor is not checked, then sessions use the default resolution and resizing can only go smaller. You can change the default to full screen and then resize down during the session if desired. Or, turn multi-monitor on and it will start in full-screen regardless of the default setting. As a bonus, for any macOS users getting a tiling effect when they resize, the multi-monitor setting will fix that.
My guess is you don’t have multi-monitor checked and a default resolution that is not full screen?
If you are curious about Smart Sizing:
  • Smart Sizing on - when the windowis resized, then what is shown is also resized in the window to fit, including aspect ratio and resulting distortion.
  • Smart sizing off - Any resizing smaller causes part of the screen to be covered and sliders to show up so you can access the covered area.
I generally prefer multi-monitor and smart sizing both on.
None of these change the underlying resolution I don’t think, but the widows are bigger so you can see them better.
Let me know if that helps,
Billy
Thanks for the suggestion and clarification, I will give it a try and let you know if it works for users.
