Allow a preferred MFA for the environment or at a linked AD group level
We would like options for automatically setting a preferred MFA for new users.
When using an AD Group reference (in Users & Groups) the Group level Authentication Connector can be set to a specific auth type but the individual members under that Group still have the default “Internal MFA”. Before these users can sign in as needed (with our required MFA) you must go set the auth connector at the user level. In our case the AD Group reference is used due to the high turnover rate of these users and so rather than work tickets for these new users, I’d like the ability to set the default Auth Connector type for either the entire environment (which would be ideal for us) or a toggle switch at the Group level that would force the contained users to the auth type of the Group. If setting the preferred MFA at the environment level, I’m imaging the need for one or more accounts to be excluded from our preferred Authentication type as a break-glass. Perhaps that could be done at the Configuration | Authentication page where we have our MFA setup.
Without this option we’ll have to continue to work tickets for all new users, in order to simply log in and set the preferred auth mfa type.
Agreed! Having to go in and select the Auth Connector for each individual user is not convenient, and probably our most frequently missed onboarding step.
Hi Mark,
I am sorry this request is so old without a response. I will look into adding this, but not sure about timeline.
Best Regards, Billy
