RDP Session to verify with MFA Code only
The option “Allow Proxy Auto Connects” in Connection Profiles is used to require secondary authentication. This means that if that is enabled, any RDP session would require both Password and MFA if MFA is enabled. It seems that verifying using MFA code should be sufficient instead of having User to enter their Password again.
By following the current design of the solution - entering both Password and MFA
