We had a comment from @Ashers2025 in Help Shape the Future of PingCastle - We Need Your Feedback ๐ - #3 by Ashers2025 about bringing PingCastle into ADUC and I just saw this today coming back from the New Year and finally caught up so I thought I could get this done in a somewhat hack-y way but gets the job done for those that may want this.
Now, disclaimer, the script was done with ChatGPT5.2 Thinking with some and a few tweaks from myself of course but I was mostly aware of how to do this with DisplaySpecifiers and the AdminContextMenu (or the ContextMenu, still never really sure on the actual difference between the two so I chose just the AdminContextMenu attribute as this is more of an admin function in the prompt) so I am not just blindly trusting AI here.
I believe this should be secure enough, just donโt go giving domain users or other well known groups access to the share otherwise you may be giving attackers access to PingCastle reports which is obviously a gold mine so be careful about it!
Setup
The script in PingCastle ADUC Setup below needs to be saved and run on a client server that will host PingCastle for anyone that uses it. The script does the following:
- Makes a new AD Group called
PingCastle_ADContextMenuwhich will control access to the share where PingCastle will be hosted - Makes a new hidden share in C:\Shares called
PingCastle_ADContextMenu$and grants the share access and NTFS access to the Administrators group and the AD Group above. - Changes all Display Specifiers (All languages) to include the new PingCastle options:
- PingCastle - View Report - Opens the latest report
- PingCastle - Run Scan - Runs a scan and opens the report afterwards
Whilst I have not done it here, an alternative setup is possible for admin workstations or similar where you would have to have the copy of PingCastle locally rather than on a share. This should run faster but obviously requires some more setup and management which is why I opted for the secure share approach to show here.
.SYNOPSIS
Quick installer for a PingCastle ADUC context menu (static Display Specifier entries).
.DESCRIPTION
- Creates AD group: "PingCastle_ADContextMenu"
- Creates SMB share (default hidden): "PingCastle_ADContextMenu$"
- Downloads latest PingCastle release ZIP from GitHub and extracts to \\server\share\Bin
- Creates context menu scripts (View Report / Run Scan) in \\server\share\Scripts
- Registers ADUC static context menu items for selected AD object classes in ALL DisplaySpecifiers locale containers
.REQUIREMENTS
- Run as: Domain admin rights for share creation on the file server + Enterprise Admin (or equivalent) rights to modify Display Specifiers.
- Modules: ActiveDirectory; SmbShare (on the share server).
- Network: Admin workstations must reach the SMB share and DCs.
.NOTES
- This runs PingCastle from a UNC path. Many orgs block executing EXEs from shares (AppLocker/WDAC/ASR).
If thatโs you, copy PingCastle locally to admin workstations instead and update the command paths.
[CmdletBinding(SupportsShouldProcess=$true)]
param(
# Where to host the share (run this on that server, or use remoting)
[string]$ShareLocalPath = "C:\Shares\PingCastle_ADContextMenu",
[string]$ShareName = "PingCastle_ADContextMenu`$",
# AD group to grant access to the share + NTFS
[string]$AdGroupName = "PingCastle_ADContextMenu",
# Which AD object classes to extend in ADUC
[string[]]$TargetClasses = @("domainDNS"),
# Menu ordering (large numbers reduce collision risk)
[int]$MenuOrderView = 15000,
[int]$MenuOrderScan = 15010
Set-StrictMode -Version Latest
$ErrorActionPreference = "Stop"
function Assert-Module([string]$Name) {
if (-not (Get-Module -ListAvailable -Name $Name)) {
throw "Required module not found: $Name. Install RSAT/feature and try again."
function Get-HostFqdn {
try {
return ([System.Net.Dns]::GetHostEntry($env:COMPUTERNAME)).HostName
} catch {
return $env:COMPUTERNAME
function Ensure-Folder([string]$Path) {
if (-not (Test-Path -LiteralPath $Path)) {
New-Item -ItemType Directory -Path $Path | Out-Null
function Ensure-AdGroup([string]$Name) {
Assert-Module ActiveDirectory
Import-Module ActiveDirectory
$existing = Get-ADGroup -Filter "Name -eq '$Name'" -ErrorAction SilentlyContinue
if ($existing) { return $existing }
if ($PSCmdlet.ShouldProcess("AD", "Create group $Name")) {
return New-ADGroup -Name $Name -SamAccountName $Name -GroupCategory Security -GroupScope Global -Path (Get-ADDomain).UsersContainer
function Ensure-Share([string]$LocalPath, [string]$Name, [string]$GroupName) {
Assert-Module SmbShare
Ensure-Folder $LocalPath
$bin = Join-Path $LocalPath "Bin"
$scripts = Join-Path $LocalPath "Scripts"
$reports = Join-Path $LocalPath "Reports"
Ensure-Folder $bin
Ensure-Folder $scripts
Ensure-Folder $reports
$existing = Get-SmbShare -Name $Name -ErrorAction SilentlyContinue
if (-not $existing) {
if ($PSCmdlet.ShouldProcess("SMB", "Create share $Name -> $LocalPath")) {
New-SmbShare -Name $Name -Path $LocalPath -CachingMode None `
-FullAccess @("BUILTIN\Administrators") `
-ChangeAccess @("$((Get-ADDomain).NetBIOSName)\$GroupName") | Out-Null
} else {
# Ensure group has at least Change on the share
if ($PSCmdlet.ShouldProcess("SMB", "Ensure share permissions for $Name")) {
Grant-SmbShareAccess -Name $Name -AccountName "$((Get-ADDomain).NetBIOSName)\$GroupName" -AccessRight Change -Force | Out-Null
# NTFS permissions (simple: group gets Modify under the share root)
$domainNetbios = (Get-ADDomain).NetBIOSName
$principal = "$domainNetbios\$GroupName"
if ($PSCmdlet.ShouldProcess("NTFS", "Grant Modify to $principal on $LocalPath")) {
& icacls $LocalPath /inheritance:e | Out-Null
& icacls $LocalPath /grant "$principal`:(OI)(CI)(M)" | Out-Null
& icacls $LocalPath /grant "BUILTIN\Administrators:(OI)(CI)(F)" | Out-Null
return @{
Root = $LocalPath
Bin = $bin
Scripts = $scripts
Reports = $reports
function Download-LatestPingCastle([string]$BinPath) {
$api = "https://api.github.com/repos/netwrix/pingcastle/releases/latest"
$headers = @{ "User-Agent" = "PingCastle-ADUC-ContextMenu-Installer" }
Write-Host "Fetching latest PingCastle release metadata from GitHub..."
$release = Invoke-RestMethod -Uri $api -Headers $headers
$asset = $release.assets | Where-Object { $_.name -match '\.zip$' } | Select-Object -First 1
if (-not $asset) {
throw "Could not find a .zip asset in the latest release. Check GitHub releases page."
$tmp = Join-Path $env:TEMP $asset.name
Write-Host "Downloading $($asset.name)..."
Invoke-WebRequest -Uri $asset.browser_download_url -Headers $headers -OutFile $tmp
# Clean bin folder but keep it existing
Get-ChildItem -Path $BinPath -Force -ErrorAction SilentlyContinue | Remove-Item -Recurse -Force -ErrorAction SilentlyContinue
Write-Host "Extracting to $BinPath..."
Expand-Archive -LiteralPath $tmp -DestinationPath $BinPath -Force
Remove-Item -LiteralPath $tmp -Force -ErrorAction SilentlyContinue
function Write-ContextMenuFiles([string]$ScriptsPath, [string]$ReportsUNC, [string]$BinUNC) {
Ensure-Folder $ScriptsPath
$viewPs1 = Join-Path $ScriptsPath "PingCastle_ViewReport.ps1"
$viewBat = Join-Path $ScriptsPath "PingCastle_ViewReport.bat"
$scanPs1 = Join-Path $ScriptsPath "PingCastle_RunScan.ps1"
$scanBat = Join-Path $ScriptsPath "PingCastle_RunScan.bat"
@ECHO OFF
REM Launch the PowerShell script with same base name and pass-through args from ADUC (ADsPath + class)
start powershell.exe -ExecutionPolicy Bypass -NoLogo -NoProfile -File "%~dpn0.ps1" %*
"@ | Set-Content -LiteralPath $viewBat -Encoding ASCII
Copy-Item -LiteralPath $viewBat -Destination $scanBat -Force
param(
[Parameter(Mandatory=`$true, Position=0)]
[string]`$ObjectPath,
[Parameter(Mandatory=`$true, Position=1)]
[string]`$ObjectType
function Get-DomainFqdnFromAdsiPath([string]`$p) {
# ADUC passes ADsPath (e.g., LDAP://CN=User,OU=...,DC=contoso,DC=com) possibly with server prefix LDAP://DC01/...
`$s = `$p -replace '^LDAP://',''
if (`$s -match '^[^/]+/.+') { `$s = `$s.Substring(`$s.IndexOf('/') + 1) }
# DN now begins at CN=... or DC=...
`$dcs = [regex]::Matches(`$s, 'DC=([^,]+)', 'IgnoreCase') | ForEach-Object { `$_.Groups[1].Value }
if (-not `$dcs -or `$dcs.Count -lt 2) { return `$null }
return (`$dcs -join '.')
`$domain = Get-DomainFqdnFromAdsiPath `$ObjectPath
if (-not `$domain) {
[System.Windows.Forms.MessageBox]::Show("Could not derive domain from ADsPath:`n`n`$ObjectPath","PingCastle - View Report") | Out-Null
exit 1
`$report = Join-Path -Path "$ReportsUNC" -ChildPath "`$domain\latest.html"
if (-not (Test-Path -LiteralPath `$report)) {
[System.Windows.Forms.MessageBox]::Show("No latest report found for:`n`n`$domain`n`nExpected:`n`$report`n`nTry 'PingCastle - Run Scan' first.","PingCastle - View Report") | Out-Null
exit 2
Start-Process `$report
"@ | Set-Content -LiteralPath $viewPs1 -Encoding UTF8
param(
[System.Windows.Forms.MessageBox]::Show("Could not derive domain from ADsPath:`n`n`$ObjectPath","PingCastle - Run Scan") | Out-Null
exit 1
`$pingCastleExe = Join-Path -Path "$BinUNC" -ChildPath "PingCastle.exe"
if (-not (Test-Path -LiteralPath `$pingCastleExe)) {
[System.Windows.Forms.MessageBox]::Show("PingCastle.exe not found at:`n`n`$pingCastleExe","PingCastle - Run Scan") | Out-Null
exit 2
`$timestamp = Get-Date -Format "yyyyMMdd-HHmmss"
`$user = `$env:USERNAME
`$outDir = Join-Path -Path "$ReportsUNC" -ChildPath "`$domain"
`$null = New-Item -ItemType Directory -Path `$outDir -Force
# PingCastle writes HTML/XML into the current working directory; use WorkingDirectory to control output location.
`$args = @("--healthcheck","--server",`$domain)
`$p = Start-Process -FilePath `$pingCastleExe -ArgumentList `$args -WorkingDirectory `$outDir -Wait -PassThru
if (`$p.ExitCode -ne 0) {
[System.Windows.Forms.MessageBox]::Show("PingCastle returned exit code: `$(`$p.ExitCode)`nOutput folder:`n`$outDir","PingCastle - Run Scan") | Out-Null
exit 3
# Try to pick the newest HTML and XML produced and copy to a stable 'latest.*' filename
`$latestHtml = Get-ChildItem -Path `$outDir -Filter "*.html" | Sort-Object LastWriteTime -Descending | Select-Object -First 1
`$latestXml = Get-ChildItem -Path `$outDir -Filter "*.xml" | Sort-Object LastWriteTime -Descending | Select-Object -First 1
if (`$latestHtml) {
Copy-Item -LiteralPath `$latestHtml.FullName -Destination (Join-Path `$outDir "latest.html") -Force
Copy-Item -LiteralPath `$latestHtml.FullName -Destination (Join-Path `$outDir "PingCastle-`$domain-`$timestamp-`$user.html") -Force
if (`$latestXml) {
Copy-Item -LiteralPath `$latestXml.FullName -Destination (Join-Path `$outDir "latest.xml") -Force
Copy-Item -LiteralPath `$latestXml.FullName -Destination (Join-Path `$outDir "PingCastle-`$domain-`$timestamp-`$user.xml") -Force
if (`$latestHtml) { Start-Process (Join-Path `$outDir "latest.html") }
"@ | Set-Content -LiteralPath $scanPs1 -Encoding UTF8
function Get-DisplaySpecifiersBaseDn {
$root = Get-ADRootDSE
return "CN=DisplaySpecifiers,$($root.configurationNamingContext)"
function Get-LocaleContainers([string]$DisplaySpecBaseDn) {
# locale containers are immediate children, named like CN=409, CN=809, etc.
Get-ADObject -SearchBase $DisplaySpecBaseDn -LDAPFilter "(objectClass=container)" -SearchScope OneLevel -Properties cn |
Select-Object -ExpandProperty cn
function Ensure-DisplaySpecifier([string]$LocaleCn, [string]$ClassName, [string]$DisplaySpecBaseDn) {
$dn = "CN=$ClassName-Display,CN=$LocaleCn,$DisplaySpecBaseDn"
try {
return Get-ADObject -Identity $dn -ErrorAction Stop
} catch {
return $null
function Add-ContextMenuValue([string]$DisplaySpecifierDn, [string]$AttributeName, [string]$Value) {
try {
$obj = Get-ADObject -Identity $DisplaySpecifierDn -Properties $AttributeName
$existing = @($obj.$AttributeName)
if ($existing -contains $Value) { return }
Set-ADObject -Identity $DisplaySpecifierDn -Add @{ $AttributeName = $Value } | Out-Null
} catch {
# Some environments may not have both attributes; ignore missing attribute errors.
Write-Verbose "Could not add value to $AttributeName on $DisplaySpecifierDn`: $($_.Exception.Message)"
function Register-ContextMenus([string[]]$Classes, [string]$ScriptsUNC, [int]$OrderView, [int]$OrderScan) {
$displayBase = Get-DisplaySpecifiersBaseDn
$locales = Get-LocaleContainers $displayBase
$viewCmd = Join-Path $ScriptsUNC "PingCastle_ViewReport.bat"
$scanCmd = Join-Path $ScriptsUNC "PingCastle_RunScan.bat"
$viewVal = "$OrderView,&PingCastle - View Report,$viewCmd"
$scanVal = "$OrderScan,&PingCastle - Run Scan,$scanCmd"
foreach ($loc in $locales) {
foreach ($cls in $Classes) {
$ds = Ensure-DisplaySpecifier -LocaleCn $loc -ClassName $cls -DisplaySpecBaseDn $displayBase
if (-not $ds) { continue }
Add-ContextMenuValue -DisplaySpecifierDn $ds.DistinguishedName -AttributeName "adminContextMenu" -Value $viewVal
Add-ContextMenuValue -DisplaySpecifierDn $ds.DistinguishedName -AttributeName "adminContextMenu" -Value $scanVal
# ---- Main ----
$serverFqdn = Get-HostFqdn
$shareUNC = "\\$serverFqdn\$ShareName"
Write-Host "Share UNC: $shareUNC"
Write-Host "Creating AD group (if missing): $AdGroupName"
$null = Ensure-AdGroup $AdGroupName
Write-Host "Creating share + folders (if missing): $ShareName"
$paths = Ensure-Share -LocalPath $ShareLocalPath -Name $ShareName -GroupName $AdGroupName
Write-Host "Downloading PingCastle (latest GitHub release) to Bin..."
Download-LatestPingCastle -BinPath $paths.Bin
$scriptsUNC = Join-Path $shareUNC "Scripts"
$binUNC = Join-Path $shareUNC "Bin"
$reportsUNC = Join-Path $shareUNC "Reports"
Write-Host "Writing context menu scripts to Scripts..."
Write-ContextMenuFiles -ScriptsPath $paths.Scripts -ReportsUNC $reportsUNC -BinUNC $binUNC
Write-Host "Registering ADUC context menu items for classes: $($TargetClasses -join ', ')"
Register-ContextMenus -Classes $TargetClasses -ScriptsUNC $scriptsUNC -OrderView $MenuOrderView -OrderScan $MenuOrderScan
Write-Host ""
Write-Host "DONE."
Write-Host "Next steps:"
Write-Host " 1) On admin workstations, ensure they can access: $shareUNC"
Write-Host " 2) Close and reopen ADUC (dsa.msc) to refresh cached display specifiers."
Write-Host " 3) Right-click a domain object โ PingCastle menu items."
Removal
Remove the share manually on the server where you installed it. To clear up the display specifiers I have included the below script to do the removal
Remove PingCastle ADUC Context Menu
function Remove-PingCastleAducContextMenus {
.SYNOPSIS
Removes PingCastle static ADUC context menu entries from all Display Specifiers (all locales).
.DESCRIPTION
Iterates:
CN=DisplaySpecifiers,<configurationNamingContext>\CN=<locale>\CN=<class>-Display
Removes matching values from:
- adminContextMenu (primary)
- contextMenu (compat - if you previously added it)
Matching is done by menu text and/or bat filename, so it still cleans up if the UNC host/share changed.
.PARAMETER TargetClasses
AD object classes whose *-Display specifiers should be cleaned up.
Defaults to the same set used in the installer.
.PARAMETER IncludeShellContextMenu
If you ever registered the same entries under shellContextMenu, include this switch to also remove them.
.EXAMPLE
Remove-PingCastleAducContextMenus -WhatIf
.EXAMPLE
Remove-PingCastleAducContextMenus -TargetClasses @("domainDNS","organizationalUnit","user","computer")
[CmdletBinding(SupportsShouldProcess=$true, ConfirmImpact="High")]
param(
[string[]]$TargetClasses = @("domainDNS","organizationalUnit","user","computer"),
[switch]$IncludeShellContextMenu
if (-not (Get-Module -ListAvailable -Name ActiveDirectory)) {
throw "ActiveDirectory module not found. Install RSAT and try again."
Get-ADObject -SearchBase $DisplaySpecBaseDn `
-LDAPFilter "(objectClass=container)" `
-SearchScope OneLevel `
-Properties cn |
function Try-RemoveValues([string]$Dn, [string]$Attr, [string[]]$Values) {
if (-not $Values -or $Values.Count -eq 0) { return 0 }
try {
if ($PSCmdlet.ShouldProcess($Dn, "Remove $($Values.Count) value(s) from $Attr")) {
Set-ADObject -Identity $Dn -Remove @{ $Attr = $Values } | Out-Null
return $Values.Count
} catch {
Write-Verbose "Failed removing from $Attr on $Dn`: $($_.Exception.Message)"
return 0
# Matchers: robust to different UNC paths / order numbers.
$isPingCastleMenuValue = {
param([string]$v)
if ([string]::IsNullOrWhiteSpace($v)) { return $false }
# Typical static menu item format:
# <order>,<menu text>,<command>
# We'll match by menu text and/or filenames.
return (
$v -match ',\s*&?PingCastle\s*-\s*View\s*Report\s*,' -or
$v -match ',\s*&?PingCastle\s*-\s*Run\s*Scan\s*,' -or
$v -match 'PingCastle_ViewReport\.bat' -or
$v -match 'PingCastle_RunScan\.bat'
$attributesToClean = @("adminContextMenu", "contextMenu")
if ($IncludeShellContextMenu) { $attributesToClean += "shellContextMenu" }
$totalRemoved = 0
$touched = 0
foreach ($cls in $TargetClasses) {
$dsDn = "CN=$cls-Display,CN=$loc,$displayBase"
# Skip if the display specifier doesn't exist for that locale/class
$ds = $null
try { $ds = Get-ADObject -Identity $dsDn -ErrorAction Stop }
catch { continue }
# Pull current values for relevant attributes
$props = Get-ADObject -Identity $dsDn -Properties $attributesToClean
$removedHere = 0
foreach ($attr in $attributesToClean) {
$existing = @($props.$attr)
if (-not $existing -or $existing.Count -eq 0) { continue }
$toRemove = $existing | Where-Object { & $isPingCastleMenuValue $_ }
$removedHere += Try-RemoveValues -Dn $dsDn -Attr $attr -Values $toRemove
if ($removedHere -gt 0) {
$touched++
$totalRemoved += $removedHere
Write-Verbose "Removed $removedHere value(s) from $dsDn"
[pscustomobject]@{
DisplaySpecifiersTouched = $touched
ValuesRemoved = $totalRemoved
ClassesProcessed = ($TargetClasses -join ",")
LocalesProcessed = $locales.Count
Note = "Restart ADUC/MMC to refresh cached display specifiers."
How to use
- Close and Re-open ADUC as prompted if you only just ran the setup.
- Right click on the Domain object and select the option you want
- You will be prompted with file access warnings about running command prompt and then powershell but it should work okay.
I am not sure if this will be useful to many or not but thought I would post it if anyone really wants it! ![]()
