Netwrix PingCastle 3.5 Released
PingCastle v3.5 brings modern authentication support, improved scanning accuracy, and more!
What’s Changed in Netwrix PingCastle 3.5
Modern Authentication for Email Notifications
PingCastle now supports Entra ID app registration for sending email notifications, replacing legacy SMTP basic auth.
  • Supports certificate and secret-based authentication
  • PowerShell scripts included to simplify setup
  • We recommend restricting the app registration to a dedicated PingCastle mailbox
Privileged Mode
A new scanner option that enables deeper inspection for certain rules:
PingCastle.exe --healthcheck --privileged --server domain.local
Improves accuracy for:
  • A-CertTempCustomSubject (ESC1) and A-CertTempAnyPurpose (ESC2) – Now checks CA Enrollment ACLs directly
  • S-Vuln-MS14-068 and S-Vuln-MS17-010 – Checks installed hotfixes on domain controllers
Rule Updates
DNS Zone Rules (A-DnsZoneUpdate1 & A-DnsZoneUpdate2)
  • Added _msdcs.* zones to critical infrastructure detection
  • Reporting now shows zone name, domain, distinguished name, and partition
Kerberoasting (P-Kerberoasting)
The old report format created duplicate entries when a user belonged to multiple privileged groups, cluttering results and breaking action plan tracking in Enterprise. Now shows one line per vulnerable user with all groups and SPNs aggregated.
SID Filtering (T-SIDFiltering)
Fixed false positives on legacy Windows 2000 intra-forest trusts. These trusts have TrustAttributes = 0 from never being updated during domain upgrades, which PingCastle previously misread as a security risk. New CrossRef filtering logic correctly identifies within-forest trusts.
Microsoft Defender ASR
Microsoft moved ASR policy locations in Windows Server 2025. PingCastle now checks all three GPO paths to ensure coverage regardless of server version.
Other Rule Fixes
  • A-DnsZoneAUCreateChild – Fixed false negatives when no DNS partitions exist on a DC. Some environments weren’t being checked at all due to an unreachable code path.
  • S-FolderOptions – Remediation guidance now shows the correct GPO path.
ASP.NET 8 Upgrade
This release upgrades PingCastle to ASP.NET 8 to align it with PingCastle Enterprise and to help reduce antivirus false-positive detections that have occasionally impacted deployments.
Changes to be aware of:
  • Larger executable (~200 MB)
    The executable is now over 200 MB because ASP.NET 8 is bundled directly inside it. This keeps execution simple.
  • Configuration file change
    Configuration moves from PingCastle.exe.config to appsettings.console.json.
  • Auto-update behavior
    Customers using the auto-update feature must run PingCastleAutoUpdate.exe twice to complete the upgrade:
    1. First run: Downloads the new version.
    2. Second run: Automatically migrates the existing configuration to appsettings.console.json.
Other Changes
  • Updated terminology from Azure AD to Entra ID throughout the product
  • New “Delete Domain” button in the UI (no more hidden URLs)
  • Improved installer with better prerequisite detection and default installation to Program Files
  • The interface has been updated to align with updated Netwrix branding, ensuring a seamless, unified experience for security teams using multiple Netwrix products.
Security Updates
This release contains important security updates. For information on the security content of this release, please review the associated security advisory.
Version Discrepancy Notice: The public GitHub repository is currently one version ahead of the Standard, Pro, and Enterprise editions hosted on our website. This increment was purely to update the BasicEditionLicense for the public release which is not needed for licensed customers, no other changes were made.
Description Case # Escalation #
LAPS pie charts display incorrect data 450719 395623
Owner permissions for ‘Rule Exception’ are misconfigured 455140 400752
PingCastle Web UI does not start after EntraID credential update 454716 400184
[SMB2SignatureNotEnabled] Invalid SMB2_NegotiateResponse structure. 395483
[Standard] The --services collection option is not listed in help 394006
[Enterprise] Infrastructure → Domains: Filters behave unexpectedly 393666
[Enterprise] Add new Functional Levels for filtering 392262
[Standard] Exit option incorrectly terminates the program. Expected behavior: go back one level 361697
Running PingCastle from a non-domain-joined machine does not work 391121
[Security] Update vulnerable packages 400967
Report email notification not showing the maturity level 411955 00466815
Microsoft Defender ASR (attack surface reduction) 410439 00463820
“Bulk actions” are never ending - even if “done” 407346 00460760
Page Refresh on “Delete” of Rule Exception removes Filter 407345 00460757
“ActiveComputers” broken after exclusion of Win10 ESU 407258 00460739
For some large HTTP GET requests, PCE web application takes far too long 406078 00459735
Unable to delete Domain and Entity from PingCastle Enterprise. 401714 00456124
False Positive for A-SMB2SignatureNotEnabled on PingCastle 3.4.1.31 395206 00450402
Exception: Some or all identity references could not be translated. 395205 00450400
Change UK spelling of Licence to US License 410486
A-LimitBlankPasswordUse Check looking in wrong GPO list. 410082
Healthcheck crashes Pingcastle when the domain name doesn’t match the domains in the license 409982
PingCastle Interactive asks for server name twice when running scanners 409659
A-AnonymousAuthorizedGPO healtcheck rule broken 407648
DnsZoneUnsecureUpdate1 uses case-sensitive comparisons for zone name 407576
Typo 406128
PingCastleAutoUpdater Multiple Section Error 405649
SMB1 Scanner signing check is invalid 404003
Inconsistent Line Spacing on Domain Page 398865
Change description for --server parameter in Help message 397490
Can’t reproduce HealthCheck Rule P-DelegationDCsourcedeleg 397380
Wrong technical explanation for HealthCheck Rule P-DelegationDCsourcedeleg 397377
HealthCheck Rules StaledMS14_068 Should Validate Actual Patch Status and Configuration 397283
HealthCheck Rule StaledMS17_010 Should Validate Installed Updates and SMBv1 Status 397282
Wrong description to HealthCheck Rule P-PrivilegeEveryone 397272
Can’t reproduce HealthCheck Rule A-DnsZoneAUCreateChild on 2025 domain. 397270
Update outdated docs.microsoft.com links to learn.microsoft.com for long-term reliability 396943
Unclear Mapping Between Filters and Table Columns for domain page 396550
Change Support Page link to Netwrix Support 396310
Remove PingCastleUpdateService from installer folders 396305
Entra: Ensure all authentications use oauth2/v2.0/token 392840
AzureAD Scan - Random Blank Line 390393
LAPS: Change MS LAPS to Windows LAPS. 357401
Plan your upgrade
Netwrix PingCastle 3.3 will reach its end of support life on August 3, 2026. To learn more, please read the Netwrix End-of-Support Policy.
Need help with this update?
Situation Action
If you have a question you’d like to ask other experts… Create a discussion in the community: PingCastle > Discussions & Questions
If you have a feature request… Let our product team know directly: PingCastle > Ideas
If you have something cool to show… Show everyone what you built: PingCastle > Show & Tell
What are your thoughts?
The download links for 3.5 seem to be missing
Currently, only the old version is available on GitHub as well.
The GitHub release has now been completed! :slight_smile:
Schitts Creek Reaction GIF by CBC
I got an email from Netwrix saying that there were 3 vulnerabilities in 3.5.0.33 Pro and Enterprise and that I should upgrade to 3.5.0.XXXX. I run Pro and .33 is the latest. Around the same time I got an email saying that 3.5 was just released. Confused.
I am chatting to the security team now and they will update this. The advisory is valid, however the affected versions should be prior to 3.5.0.33 and not prior to or equal to 3.5.0.33. The solution will be updated.
The official fixes section is definitely correct. All these issues were resolved in 3.5.0.33.
Hi there! Thanks for letting us know. The download links for version 3.5 are now available on the customer portal. Please let us know if you run into any other issues!
Update (February 5, 2026)
We observed that the recent builds were not signed correctly due to a sequencing issue in our build pipelines. We have removed 3.5.0.33 from the product website and have added 3.5.0.37 which effectively supersedes this. No code changes in the product have been completed for this release, only changes to the pipelines that build and release PingCastle.
We have an Auditor license, and in version 3.5.0.37, there is no longer a PingCastle.exe.config file. Where do I store my license key?
Hi there,
In the appsettings.console.json. The first section should be for the license.
My license isn’t being recognised in the new appsettings.config.json file. Do I need an updated license?
Hi there Richard,
There shouldn’t be issues using your license in the appsettings.console.json file.
It should look a bit like this
  "License": {
    "License": "PC2....<the rest of your license here>"
Do you have any errors or anything showing?
If this is okay then it may be best to drop the Netwrix Support a ticket so they can help you.
Cheers
Thank you for your response.
Yes it does look like that, so I’ve opened a support ticket.
I just want to check if I was doing something wrong first :slight_smile:
Hello, it seems that the DC “AzureADKerberos”, which is present when Kerberos Cloud Trust is configured, is detected as having the DC vulnerability MS14-068, which is apparently false and unfairly sets the score to 100.
Yes, we have a bug in to get this resolved in the next release.
We have noticed the same thing with our standalone Pingcastle v3.5.0.37.
Hi There , just downloaded 3.5.0.37 and it is now reporting that the “A LDAP authentication without signature enforcement was allowed” this does not get reported on ver 3.4.2.66 when run at the same time? i have checked the settings on the DCs and they are all set correctly to enforce Sighing, can this be investigated
    The above does not seem to work for us. It does not convert our config into the json. And even manually inserting the license does not work
Inserting the licens works now. But it says “You are not using a supported version of PingCastle”
This is a known issue and will be fixed in a small patch release hopefully on Tuesday.
