Here is the bugfix list for PingCastle version 3.3. This topic will be kept updated with new fixes that get released over time.
Bugfixes
| Component | Product(s) | Description | Fixed in | Released on | Case | Escalation |
| Console Application | All | Update F-Secure Link | 3.3.0.1 | 2024-09-26 | 356273 | N/A |
| Console Application | All | Fix issues with MaxNumDisplayAccount where implementation removed the rule when more than 100 were matched. | 3.3.0.1 | 2024-09-26 | 357408 | N/A |
| Console Application | All | LTSC OS for 19044 are not correct in the reporting | 3.3.0.1 | 2024-09-26 | 357977 | N/A |
| Web Application | Pro, Ent | Computers Sunburst Graph Filters for WithSidHistory seem broken | 3.3.0.1 | 2024-11-14 | 356427 | N/A |
| Web Application | Pro, Ent | Fix permissions formatting on cloud reports | 3.3.0.1 | 2024-11-14 | 356427 | N/A |
| Web Application | Pro, Ent | Agents can be used even when not enabled | 3.3.0.1 | 2024-11-14 | 362854 | N/A |
| Web Application | Pro, Ent | User deletion API does not work when user is logged in | 3.3.0.1 | 2024-11-14 | 362848 | N/A |
| Console Application | Standard, Pro, Ent | Password Last Set not set correctly in multiple tables | 3.3.0.3 | 2024-12-10 | 365582 | N/A |
| Web Application | Pro, Ent | Fix email preview and email sending with new banner | 3.3.0.3 | 2024-12-10 | 364642 | N/A |
| Installer | Pro, Ent | Installer needs to check for .NET 8 and not just any .NET Version installed | 3.3.0.3 | 2024-12-10 | 364808 | N/A |
| Web Application | Pro, Ent | Claims permissions on entities not working | 3.3.0.5 | 2025-01-14 | 00430048 | 368888 |
| Web Application | Pro, Ent | Relax NETBIOS Name restriction for historic domains | 3.3.0.6 | 2025-02-11 | 00434099 | 374041 |
| Installer | Pro | Unable to install product. Unknown error | 3.3.0.7 | 2025-02-13 | 00434868 | 374386 |
| Console Application | All | Windows LAPS not showing | 3.3.0.8 | 2025-02-19 | 00435091 | 374567 |
| Console Application | All | Azure Token Expired | 3.3.0.8 | 2025-02-19 | 00435212 | 374636 |
