The Ticket System Is Unavailable Now
Dear Sir/Madam,
I want to submit a ticket in your system, but an error occurs. It shows that unable to create a ticket, please try again later.
Please fix the problem. Because there is no other way to contact the support in order to report a problem.
Hi Jessica,
I just tested our ticket system and successfully created a ticket.
Please try again at Support tickets
If you continue to encounter issues you can also reach support by calling any of the phone numbers in the last quarter of the page Support Center | Netwrix. If for any reason your call is not answer, leaving a voicemail clearly identifying yourself and your organization will create a ticket and the next available Support Engineer will contact you.
