Syslog host field needs to be changed with FQDN, not IP address
syslog host field needs to be changed with FQDN, not IP address
Requesting to have a setting that can select FQDN or IP for whichever the environment uses. Our environment the logs are sent to a VIP on a port which then sends them to sentinel. In our case it expects FQDN not the IP.
We had to have our log team make changes on their side until we have a feature available.
Hello Doug,
Thank you for sharing your feature request!
Please allow me to look into the possibilities for achieving this and get back to you with a response.
Kind Regards,
Simona
Hi Doug,
While we started to look into this feature request, to make sure we fully understand the scenario you’re aiming to achieve, we’ll need a bit more detail. Therefore, could you please elaborate on your use case and, if possible, share a specific example?
This will help us get a complete picture and provide the best possible solution.
Looking forward to your reply.
Kind Regards,
Simona
The logging on the old version of your software used to push logs to the SEIM as hostname. The new logging pushes logs via the IP. The ability to change the way logs are being sent would be good. Eduard Alexandru Nut was the technician that helped me open this feature request. You may want to follow up with him for more information
Hi Doug,
Thank you for your reply.
I’ll check then also with Eduard and let you know if there’s additional information needed from your side.
We’ll keep you updated as soon as we have a response to share. Please note that it may take a while.
All the best,
Simona
Hello Doug,
As an update, I would like to inform you that this request has been submitted internally for further technical investigation and it will take some time.
Upon conclusion, we will notify you.
In the meantime, we thank you for the patience.
Kind Regards,
Simona
Hi,
Thank you for your patience.
We’re happy to let you know that this will be supported in our upcoming release. When configuring your SIEM destination in Endpoint Protector, the Server IP or DNS field will accept both IP addresses and hostnames/FQDNs. By entering your VIP hostname directly in that field instead of an IP address, the logs forwarded to your SIEM will reflect the FQDN format you need.
Once the release is available, you can update your SIEM destination configuration by navigating to the SIEM Integration settings and replacing the current IP address with your FQDN. Your team’s current workaround should no longer be necessary after that.
Best regards,
Mihai
