Request to enable SIEM log forwarding formats (CEF or LEEF format)
Request to enable SIEM log forward format in CEF or LEEF format.
The EPP server is sending SIEM logs in syslog - RFC-5424 format. When using the TCP protocol, we have the option to encrypt communication to each SIEM server, but currently, the logs are being forwarded over UDP. We need to forward them in CEF or LEEF format, so requesting to enable/change the log forwarding format accordingly.
Currently logs are being forwarded in plain text format.
Hello Divya,
Welcome to Netwrix Community and thank you for sharing your feedback.
Please allow us some time to verify the request internally and get back to you with a response as soon as possible.
Regards,
Simona
Hello Divya,
We’re pleased to let you know that your feature request has been approved for further investigation. This process may take some time, as it requires further analysis and prioritization within our roadmap.
While the results won’t be available in the near future, we’ll make sure to share updates once we reach solid conclusions.
We truly appreciate your patience.
Kind Regards,
Simona
Hi Divya,
I would like to inform you that your item is still valid on our desk and once the investigation is completed, we will update you at the appropriate time. As this process takes time while we navigate through our full agenda, we truly appreciate your patience!
Best Regards,
Simona
