Add Option to Use Hostname Instead of Container ID in Logs
Add an option to use the host server’s hostname instead of the container ID in logs for better SIEM integration and easier correlation.
Currently, logs forwarded from containers include the container ID, which is dynamic and does not provide meaningful context for SIEM analysis. My idea is to introduce a configuration option that allows users to include the hostname of the host server in the logs instead of the container ID. This would enable security teams to correlate events more effectively, troubleshoot issues faster, and maintain consistency across nodes and services. The feature could be implemented in Fluentd/Fluent Bit or within the log forwarding configuration as a toggle or environment variable.
The problem is that container IDs are not helpful for SIEM correlation because they change frequently and do not map to physical or virtual hosts. Hostnames provide a stable and meaningful identifier that aligns with enterprise security practices. This solution is best because it requires minimal changes (just a configuration option) and significantly improves log usability for monitoring and incident response.
Currently, we attempt workarounds like hardcoding hostnames in configuration files or passing environment variables manually (e.g., HOST_HOSTNAME=${HOSTNAME} in docker-compose), but these approaches are error-prone, require manual intervention on every node, and do not scale well across large environments.
Hi Virat,
Thank you for this request!
This is possibly something that can be done without a product change as the log forwarding update has a dedicated config file, fluent.conf, which is used to set destination parameters for receiving server/SIEM.
The challenge here is fluentd’s plugins and dependencies have changed over the years so it’s been work to keep up with that, which was initially done via the Customer Success team and not R&D.
Hence this article being created and published from their work in the logging world with different SIEMs - Forward Logs to Syslog Servers and SIEM Solutions | Netwrix Product Documentation
secureone@example:~$ sudo cat /secureone/conf/fluentd/fluent.conf
<source>
@type forward
#format json
#time_key time
#time_format %Y-%m-%dT%H:%M:%S
</source>
<filter docker.**>
@type parser
#time_parse false
time_key key3
format json
hostname $hostname
key_name log
reserve_data true
#time_format %Y-%m-%d %H:%M:%S,%L
</filter>
<match **>
@type stdout_pp
pp true
time_color blue
tag_color yellow
record_colored true
</match>
Please let us know if this information helps.
- Dan
Hi Don,
Thank you for the update and for the detailed context around the logging configuration and the fluentd plugin changes.
I wanted to share that I’ve already worked closely with Support and we tried all available configuration options to get the hostname included in the logs — including using $hostname and attempting to pass a more “friendly” hostname through the default fields. Unfortunately, none of the available combinations achieved the desired result, and modifying the default field for this purpose isn’t technically feasible at the moment.
Given these limitations, I submitted this as a feature request so that native hostname support can be implemented directly in the product rather than depending on fluentd behavior or custom workarounds.
I appreciate your insights and the documentation link — it’s helpful background. Please let me know if there are any additional options we should revisit or if R&D needs any further details from my side.
Thank you,
Virat
Hi Virat,
Thank you for the detailed request and clear explanation—this is a great use case.
This functionality is now implemented and will be available starting April 28, 2026 in the NPS-D release.
Availability:
NPS-D 2.22.13, 26.03.1, or later
You can configure log forwarding to use the host server hostname instead of the container ID, which should significantly improve SIEM correlation and overall log clarity.
Documentation:
Best regards,
Tomasz
Thank you for taking the time to implement this enhancement.
It will be a significant help for large organizations in implementing effective SIEM alerting.
Best regards,
Virat Patel
