SQL error on NTP's SQL server
For all the SQL masters out there, we’re getting an error from our NTP SQL server and am trying to determine if this has been seen before with NTP.
Here’s the error (SQL_Server_Name in place of actual server name):
Infrastructure DBSS Foglight Situation: SQL_Server_Name : SQL Server_Name File Group Utilization. The Group File PRIMARY in database NVMonitorData is 98.08 % full.
We have had issues in the past setting up the database maintenance and as of now, we do not have anything configured, we just get SQL client error if we try to use it. We are working with our DBA team to see if we can come to an understanding on rights to make this happen. Would modifying our database maintenance settings possibly help to fix this?
Thanks!
Hey Art,
This seems to just be a warning indicating that your database is getting full. Setting up DB Maintenance is critical for NTP and should be a priority to try to get resolved with your DBA team. I would expect it to help with this issue as well, as it will clean up old data, helping with storage utilized.
