We suggest adding a scheduling option to System Backup v2 to improve backup automation and reduce manual operational effort.
Hello, this is Donghyun Kim.
I would like to suggest adding a scheduled backup feature to the System Backup v2 functionality in EPP.
Currently, System Backup v2 must be performed manually each time, which can be somewhat inconvenient from an administrative perspective.
If a scheduling option were added—similar to what is available for the audit log backup feature—it would greatly enhance the automation and efficiency of EPP backup operations.
We would appreciate your consideration. Thank you.
At the moment, we are performing System Backup v2 manually, which adds operational overhead.
