What’s Changed in Reporting Only Module 3.3
Enhancements
- Service account tagging for AD sync, now with autocomplete for faster, more consistent tagging.
- Organizational Unit (OU) sync support for more granular scoping and reporting.
Investigations
- Fixed a missing error message for empty filter values on the Events Over Time and Top Resources tabs.
- Fixed a server error when filtering NTP-based investigations by time of day.
- Fixed the Object Move operation incorrectly displaying as “Renamed” in NTP investigation descriptions.
- Fixed the time filter not returning correct results in some investigation scenarios.
Identity & Directory Sync
- Fixed re-created objects incorrectly retaining links to deleted object details.
- Fixed computer objects displaying as user objects after deletion.
- Fixed cancellation requests for AD history sync failing to send when navigating between pages.
Service Accounts & Tags
- Fixed the Tags page returning duplicate entries.
- Fixed audit log entries not being created when tags were added or deleted.
Authentication & Access
- Fixed the MFA authentication provider not being set correctly when adding the first password for an admin post-install.
- Fixed the login error message failing to display when critical external authentication configuration is missing.
- Fixed a server error at login for new users added via SAML group membership.
- Fixed a misleading error message on the login page when a password change is required.
- Fixed username not displaying on the credential profile.
Platform & Administration
- Fixed a server error when exporting logs with PostgreSQL hosted on a separate server. (Escalation 00483739)
- Prevented creation of duplicate-named entries on the Integrations page.
- Fixed the “GET Favorites” request returning an empty array.
- Fixed missing CSS styles for radio buttons in email integration settings.
- Fixed broken styling on the recipients field of the export-via-email form.
- Fixed the Move Database feature referencing a previous product name.
- Fixed a poor user experience during migration setup.
- Fixed installer warning message colors to match the current theme.
Need help with this update?
| Situation | Action |
| If you have a question you’d like to ask other experts… | Create a discussion in the community: Threat Prevention > Discussions & Questions |
| If you have a feature request… | Let our product team know directly: Threat Prevention > Ideas |
| If you have something cool to show… | Show everyone what you built: Threat Prevention > Show & Tell |
What are your thoughts?
