Reporting Only Module 3.1 Released
What’s Changed in Reporting Only Module 3.1
Netwrix Rebranding
The interface has been updated to align with Netwrix branding, ensuring a seamless, unified experience for security teams using multiple Netwrix products.
Cumulative fixes since Reporting Only Module 3.0
  • External Authentication Provider Naming - Users can successfully rename external authentication providers without encountering errors.
  • Multi-Value Field Export - Multi-value fields such as tags export correctly to CSV files with proper formatting instead of as object references, making exported data immediately usable.
  • Investigation Attribute Access - Fixed the description for object renames.
  • Affected Object Filter Autocomplete - The Affected Object filter displays autocomplete suggestions when using read-only investigation mode, improving filter usability.
  • Investigation Logging - Investigation queries with verbose logging complete without encountering parsing errors that could interrupt analysis.
  • Log Export Progress - Users see visual progress feedback when exporting large log files, improving transparency during long-running exports and preventing confusion about system responsiveness.
  • Email Report Delivery - Scheduled reports deliver successfully via email without encountering subscription errors, ensuring reliable report distribution.
  • Service Restart Reliability - Background services automatically restart if they stop unexpectedly, ensuring continuous monitoring without manual intervention.
  • Login Compatibility - Users can successfully log in even when very old cached data exists in their browser storage, preventing access issues after extended periods between logins.
  • Installer Action Execution - The installer only executes post-installation actions when installation completes successfully, preventing errors during failed installations.
Need help with this update?
Situation Action
If you have a question you’d like to ask other experts… Create a discussion in the community: Threat Prevention > Discussions & Questions
If you have a feature request… Let our product team know directly: Threat Prevention > Ideas
If you have something cool to show… Show everyone what you built: Threat Prevention > Show & Tell
What are your thoughts?
