NTP Reporting Only Module Bug Fix List
:pushpin: Looking for a bug fix list for all versions of Threat Prevention - Reporting Only Module?
All bug fixes will automatically be added here!
3.3 Updates
Reporting Only Module 3.3.88 Released
September 23, 2026
Security
  • Updated front-end third party dependencies
  • Updated OpenSSL to version 4.0.2
  • Updated DotNet to version 10.0.10
  • Updated PG to versions 14.24.2 and 18.6.3
Bug Fixes
  • Resolved an issue where an error screen was sometimes displayed at login after an upgrade.
  • Fixed an issue in the Tags details panel where the description field did not wrap long text and could clip or scroll unexpectedly; also corrected related layout issues with grid alignment and totals display.
  • Resolved an issue where users were unable to set a new password or log in after a password reset, if the admin account was originally created on version 2.7.
Reporting Only Module 3.3 Released
August 18, 2026
Investigations
  • Fixed a missing error message for empty filter values on the Events Over Time and Top Resources tabs.
  • Fixed a server error when filtering NTP-based investigations by time of day.
  • Fixed the Object Move operation incorrectly displaying as “Renamed” in NTP investigation descriptions.
  • Fixed the time filter not returning correct results in some investigation scenarios.
Identity & Directory Sync
  • Fixed re-created objects incorrectly retaining links to deleted object details.
  • Fixed computer objects displaying as user objects after deletion.
  • Fixed cancellation requests for AD history sync failing to send when navigating between pages.
Service Accounts & Tags
  • Fixed the Tags page returning duplicate entries.
  • Fixed audit log entries not being created when tags were added or deleted.
Authentication & Access
  • Fixed the MFA authentication provider not being set correctly when adding the first password for an admin post-install.
  • Fixed the login error message failing to display when critical external authentication configuration is missing.
  • Fixed a server error at login for new users added via SAML group membership.
  • Fixed a misleading error message on the login page when a password change is required.
  • Fixed username not displaying on the credential profile.
Platform & Administration
  • Fixed a server error when exporting logs with PostgreSQL hosted on a separate server. (Escalation 00483739)
  • Prevented creation of duplicate-named entries on the Integrations page.
  • Fixed the “GET Favorites” request returning an empty array.
  • Fixed missing CSS styles for radio buttons in email integration settings.
  • Fixed broken styling on the recipients field of the export-via-email form.
  • Fixed the Move Database feature referencing a previous product name.
  • Fixed a poor user experience during migration setup.
  • Fixed installer warning message colors to match the current theme.
3.2 Updates
Reporting Only Module 3.2.142 Released
September 23, 2026
Security
Reporting Only Module Patch Version 3.2.138 Released
August 18, 2026
Improvements
  • Added ADCS filters for Threat Prevention investigations
  • Filters are now retained when switching investigation sources, with query results updating reliably.
  • PostgreSQL 18 installation warning now flags unsupported PostgreSQL 18 configurations during install.
Bug Fixes
Investigations
  • Fixed a server error when retrieving Azure authentication events during investigations.
  • Fixed a crash in the Abnormal Time detection job under certain user session conditions.
  • Fixed a server error in investigations when filtering by “Time of Day” with a specific day or time using NTP data.
  • Fixed the Perpetrator filter not working correctly with application-based investigations.
  • Fixed an issue where recreated objects could incorrectly retain links from previously deleted objects in object details.
  • Fixed computer objects incorrectly displaying as user objects after deletion.
  • Fixed tag additions and deletions not generating audit log entries.
  • Fixed search results not clearing correctly when using “View Critical Accounts” on the Service Accounts page.
  • Fixed “Sensitive” tag assignment from NAA integration.
  • Fixed multi-factor authentication provider not being set correctly when creating the initial admin password on a fresh installation.
  • Fixed a login error for users added via group membership using SAML authentication.
  • Fixed incorrect date formatting displayed in threat notifications. (Escalation 00484117)
  • Fixed a server error that occurred when exporting logs while PostgreSQL is hosted on a different server. (Escalation 00483739)
  • Fixed the Favorites API returning an empty result when requesting all-time data.
  • Fixed styling issues with radio buttons on the email integration settings page.
Reporting Only Module 3.2 Released
May 14, 2026
  • Fixed Okta OIDC integration sometimes preventing web console from loading. (Escalation 432708)
  • Fixed the installer warning message colors not matching the updated design.
  • Fixed an infinite request loop and gray screen occurring after a successful SAML/OpenID Connect login.
  • Fixed Active Directory moved objects being logged as renamed instead of moved.
  • Fixed the error recovery screen not allowing navigation to configuration pages.
  • Fixed a user-friendly error message not appearing when NTM starts with PostgreSQL stopped.
  • Fixed the “About Threat Manager” system settings page displaying an error screen.
  • Fixed AD synchronization history showing no results.
  • Fixed the backend service monitor not functioning correctly after service startup.
  • Fixed an installer version detection issue that blocked installation when the same or newer version was already installed.
  • Fixed the authentication provider settings displaying the wrong value after switching providers.
  • Fixed Favorites investigations remaining visible after user permissions were removed.
  • Fixed excessive duplicate logout requests being sent during sign-out.
  • Fixed incorrect target and client column data for file system events from Isilon data sources.
  • Fixed various UI components displaying outdated visual styles and misaligned checkbox elements.
  • Fixed an empty error notification appearing for invalid integration URLs.
  • Fixed the database availability API endpoint returning incorrect responses.
3.1 Updates
Reporting Only Module Patch Version 3.1.128 Released
February 26, 2026
  • Fixed the inconsistent design across steps in the confirmation dialogs
  • Replaced the legacy modal dialog with an updated dialog component on the service configuration page for editing descriptions
  • Added a validation check during installation that reports an error if the PowerShell execution policy is incompatible
  • Added various styling fixes for look-and-feel consistency
Reporting Only Module 3.1 Released
February 5, 2026
No bugs were fixed in this update.
3.0 Updates
Patch Version 3.0.157 Released
November 25, 2025
This release delivers key performance improvements, system stability updates, and several critical fixes.
Important notes
  • A PostgreSQL update is required. Please allocate additional time for the data migration process to complete.
  • Netwrix Threat Prevention customers are strongly encouraged to update to the latest release for optimal performance.
Performance improvements
  • Enhanced database query performance, resulting in faster investigation loading times.
  • Implemented asynchronous logging to reduce the impact on core processing operations.
Bug fixes
  • Investigation save operations now provide clear validation messages when required fields are missing
  • Investigations correctly display activity data across multiple time zones
  • User accounts containing special characters in their names can now log in successfully
  • The credential profile editor displays the correct credential information for all entries
  • Direct member group information updates correctly during synchronization
  • Investigation file path filtering includes both file and folder event types
  • Integration test connections validate properly for new data sources
Patch Version 3.0.143 for Reporting Only Module Released
September 18, 2025
Enhancements
  • Logging Framework – Enhanced logging with improved asynchronous processing support and buffer monitoring.
  • Hybrid Object Linking – Improved object linking to better support hybrid Active Directory and Azure environments, enabling stronger cross-platform identity correlation.
Bug Fixes
  • Integration Configuration – Resolved an issue that prevented test connections to newly configured Netwrix Threat Prevention data sources (used by Threat Manager).
Security Updates
  • Dependencies – Updated JavaScript libraries (axios, superagent, and testing frameworks) to remediate security vulnerabilities.
  • Data Validation – Improved input sanitization in integration service database queries.
  • Database Security – Upgraded PostgreSQL to version 14.19 to address known security issues.
  • Runtime Components – Updated .NET runtime prerequisites to version 8.0.19 for enhanced stability and security.
Patch Version 3.0.139 Released
September 2, 2025
This release replaces hotfix 3.0.135, which was withdrawn after an issue was identified in Group Membership calculations during Active Directory synchronization. This issue has been resolved in 3.0.139, and all fixes and enhancements from 3.0.135 are included in this release.
Authentication & Authorization
  • Added group-based authorization support in User Access for OpenID and SAML configurations
Security Improvements
  • Enhanced SSL certificate validation for secure service communications
User Interface
  • Corrected password form styling on authentication pages
  • Fixed subscription list display inconsistencies
  • Resolved investigation query issues with wildcard patterns
Data Management
  • Improved database view synchronization for complete user representation
  • Optimized database migration scripts for improved upgrade performance
Other
  • Fixed an issue in Group Membership calculations during Active Directory synchronization
Patch Version 3.0.135 for Reporting Only Module Released
August 14, 2025
User Interface
Data Management
Patch Version 3.0.121 for Reporting Only Module Released
July 10, 2025
  • Fixed license expiration issue in fresh installs
  • Fixed SSO authentication types incorrectly showing for the built-in admin
  • Added “Starts With” and “Ends With” operators to “Attribute New Value” and “Attribute Old Value” investigation filters
Patch Version 3.0.112 for Reporting Only Module Released
June 24, 2025
  • Significantly reduced application load time after login
  • Added a new and improved login page
  • Improved admin password setup guidelines
  • Improved ordering in the main search bar results
  • Improved interface for configuring NTP integrations
  • Improvements to User Access configuration:
    • Removed deleted objects from the search results
    • Added icons to search results to distinguish groups and users
    • Fixed issues when adding new entries
  • Made “Two-page login” the default setting for MFA
  • Fixed various issues with SSO (OpenID, SAML) authentication providers
  • Improved error handling and error notifications for internal authentication providers
  • Fixed issues and improved the interface for MFA
  • Fixed an issue causing an AD sync failure due to a TGT lifetime silo lacking an associated policy
Patch Version of Reporting Only Module 3.0.95 Released
April 24, 2025
  • Fixed the issue with deleting an NTP configuration from integrations
  • Fixed issues with the email service in SSL-enabled environments
  • Fixed autocomplete for domain filter in investigations
  • Fixed incorrect owner being displayed for some investigations
Reporting Only Patch 3.0.91 Released
April 10, 2025
In this hotfix, we addressed various issues relating to the Reporting Module:
  • Removed the requirement to perform “ping” during AD sync configuration
  • Simplified OpenID authentication provider configuration form
  • Updated User Access configuration for authentication providers
  • Added guidelines for ADMIN password requirements in User Access
  • Added a column to User Access to display the type of entry (user or group)
Patch Version 3.0.90 for Reporting Only Module Released
March 27, 2025
In this hotfix, we addressed various issues relating to the Netwrix Threat Manager Reporting Only Module:
  • Upgraded PostgreSQL to 14.17
  • Added Entra ID SAML integration
  • Added Entra ID OpenID integration
  • Added automatic cache refresh for the web application after upgrade
  • Improved formatting and styling of emails
  • Improved notifications during PostgreSQL upgrade
  • Added a limit to the number of concurrent AD Syncs to reduce database resource contention and boost overall system performance
  • Improved AD Sync group membership calculation
  • Fixed MFA reset for specific users in a group user access
