PowerShell Repository for managing and reusing scripts easily
Create a functionality that will allows us to manage the scripts we use in a centralized location that can be assigned to different activities. This will allow us to reuse existing code and manage scripts at a central location in NPS. Having version control capabilities in that will be cherry on top.
we use external script repositories like GitHub
I fully agree that this feels like a big need for the platform. I would even suggest to go one step further and roll the custom Powershell activity step into a custom activity step that can expose multi-select fields, custom input, etc, in a similar way to the built-in activity steps. The current need to make sure you keep multiple activities updated if they re-use Powershell code is tedious and clunky.
Hi Sony & David,
These are great requests and I absolutely see how they will improve the user experience for those taking advantage of our customer PowerShell functionality.
I will add these suggestions to the backlog, however this does look like a larger project that we may not be able to work on soon. I will let you know if this work makes it into our current work.
- Dan
