Add options and secure options to PowerShellSync pakage
This feature is already available for the PowerShellProv pakage and should also be set for the PowerShellSyn one.
The idea behind is to be able to configure parameters that will be sent to the script when it is executed.
Allows to avoid hardcoding the values in the script it self
  • Hardcoded values in the script: not secure and heavy to maintain
  • A side file containing the credentials: heavy to configure and use
  • Read the values from a clear text appsettings.agent.json file: not secure
Hi @hazem.taouai
Thanks for your feature request. We’ve added it to the backlog, and will keep you updated with the progress. :slight_smile:
