Password Secure 26.8.10 Released: Complete Recycle Bin Cleanup
Netwrix Password Secure 26.8.10 is here with expanded recycle bin controls, web-based password rule management, and fixes for HSM login access, Active Directory profile switching, and more.
Password Secure 26.8.10 Now Available
This release brings improved recycle bin controls, expanded password rule management, and a set of reliability fixes across the Web App, Windows App, Server, Server Manager, Browser Extension, and MSP components.
This release introduces no breaking changes and is recommended for all customers.
Highlights
Complete recycle bin removal
The web application and Windows application now let you permanently remove deleted documents, users, organizational units, roles, applications, and forms directly from the recycle bin.
Manage password rules from the web application
Password rules can now be managed directly in the web application’s advanced view, no longer requiring a separate tool.
HSM login fix restores access
Users without the “Is database administrator” right can once again log in when a database is configured to use a Hardware Security Module (HSM) to store its keys.
New
Web application: Advanced view and Windows application
  • You can now use the recycle bin to completely remove deleted documents, users, organizational units, roles, applications, and forms, too.
  • You can now manage password rules using the web application.
Improved
Windows application
  • The Windows application now uses the most recent PuTTY version (0.84) for SSH connections.
  • Using Public Key Infrastructure (PKI) as a second factor now also allows certificates from Cryptography API: Next Generation (CNG) Key Storage Providers. This also affects the Autofill add-on.
  • Updated several third-party dependencies to their latest compatible versions. These updates bring in bug fixes, security-related fixes, performance improvements, and maintenance changes from upstream. This also affects all other Windows components, both client-side and server-side.
  • The “Multiselection” toggle now behaves and looks like a checkbox.
Browser extension
  • The extension sometimes entered credential data in forms that aren’t login forms. New limitations minimize this behavior.
Fixed
All clients with server connection
  • When a database uses a Hardware Security Module (HSM) to store its keys, users without the “Is database administrator” user right can log in again.
Windows application
  • You can now switch the Active Directory profile of roles from end-to-end (E2E) encrypted profiles to MasterKey profiles again.
Web application
  • The web app now respects the browser’s language settings again if there is no explicit language set.
Server Manager
  • The web application no longer spams the error log with “VerifyObjectRight: Insufficient right” entries.
  • Managed Service Providers can now create customers without using a database template again.
The following table contains a comprehensive list of updates and fixes introduced in this version.
Component Description Case # Escalation #
Web app The web app now respects the browser’s language settings again if there is no explicit language setting set. 451072 4310017, 4309994, 4309718, 4309594, 4309570, 4309430
Server Manager The error log on the Server Manager no longer gets spammed with “VerifyObjectRight: Insufficient right” entries when using the web application. 447195 4309828, 4309565, 4309256, 4309419
Server When a database is configured to use HSM to store its keys, users without the “Is database administrator” user right can log in again. 451673 4309993
Windows App, Autofill Add-on Using PKI as a second factor now also allows certificates from CNG Key Storage Providers. 450934 4309902
Windows App The Active Directory profile of roles can be switched from E2E-encrypted profiles to MasterKey profiles. 451663 4309771
Browser extension The browser extension sometimes entered credential data in forms that are not login forms. We added some limitations, so this behavior should be reduced to a minimum. 444110 4309697
MSP Managed Service Providers can now create customers without using a database template again. 450814 4309942
Compatibility
The following client versions are compatible with Netwrix Password Secure Application Server 26.8.10:
  • Windows & Web App: >= 26.8.10
  • Browser Extensions & API/SDK: >= 26.3.100
The following Netwrix Password Secure Application Server versions are compatible with the Password Secure Browser Extension 26.8.10:
  • Application Server: >= 26.3.100
Need help with this update?
Situation Action
If you have a question you’d like to ask other experts… Create a discussion in the community: Password Secure > Discussions & Questions
If you have a feature request… Let our product team know directly: Password Secure > Ideas
If you have something cool to show… Show everyone what you built: Password Secure > Show & Tell
What are your thoughts?
Any known problems regarding server manager login after updating? In one environment the login was no longer possible. Compare certificate thumbprint was used to match the certificate used in the base configuration exactly. Sadly a restore was performed before I could investigate further. A 4096 Bits webserver certificate from a windows -ca is in production.
Yes, we also had similar problems after the update.
Hi, everyone,
Are there any updates on this issue? Is it currently recommended to install the update?
We’re still waiting for a reply. It seems the version has a bug. Please provide an update as soon as possible.
We use the option for DNS for this issue. In almost every update this option gets resetted and magically the DNS setting survives when used. It’s pretty annoying but at least it seems to work.
We’re looking into this and will have a reply for you by tomorrow morning. Thanks for your patience!
Anybody else recognizing problems with autofill feature in the browser add-on v26.8.10.34187? It seems like there is a problem e.g. on SAP login sites abc.crm.cloud.sap/auth/login where the browser add-on shows matching passwords, but doesn’t autofill them.
This affects not only DNS resolution (comparison of the server DNS name), but also the certificate configuration in the base configuration.
In particular, it was determined that the valid certificate was removed from the Base Configuration and, instead, an invalid certificate was provided. After the certificate was switched, the connection could be restored. To better understand the cause of this behavior and to find a lasting solution, it would be extremely helpful to receive more information about why the certificate is removed during the update.
Thanks for flagging this. We weren’t able to reproduce it as a bug on our end, so to get your specific environment looked at, please submit a support ticket here: https://customer.netwrix.com/tickets.html
Thanks for the detailed writeup. We haven’t been able to reproduce a certificate being removed or replaced during the update on our end, but the specifics you’ve shared (base configuration cert swap, DNS comparison angle) point to something environment-specific worth investigating properly. Could you please open a support ticket via the Customer Portal (https://customer.netwrix.com/tickets.html) so our team can dig into the logs and reproduce this against your setup? That’ll let us trace exactly why the cert was dropped during the update.
Thanks for reporting this. We haven’t been able to reproduce an autofill failure on SAP login pages on our end, but this looks worth investigating on your specific setup (browser, add-on version, and site markup can all affect autofill detection). Could you please open a support ticket via the Customer Portal (https://customer.netwrix.com/tickets.html) with the browser/version you’re using and, if possible, a screen recording of the matching-but-not-autofilling behavior? That’ll help our team trace exactly where the autofill logic is failing on that page.
Hey, I just installed this update and also got this error.
I saw in the server logs that after the reboot the password secure sevices registered on the ipv6 adapter, thats why the DNS issue came up. I disabled ipv6 in the server adapter and after the reboot it worked again.
