Extend the Okta add-on with additional authentication eventTypes and improve the Where/What field mapping in transformer.json.
The current add-on ships with three queries: user.authentication.sso, user.session.start, and user.authentication.verify. This covers basic login events but leaves significant gaps in authentication visibility.
I would like to propose the following additional eventTypes:
Session lifecycle:
- user.session.end
- user.session.clear
- user.session.access_admin_app
MFA and sign-on policy:
- user.authentication.auth_via_mfa (covers all MFA methods: Okta Verify push, TOTP, Google Authenticator, hardware tokens, etc.)
- policy.evaluate_sign_on
- application.policy.sign_on.deny_access
MFA push notifications:
- system.push.send_factor_verify_push
Administrative actions:
- eventType sw “system.admin”
The sw (starts with) operator captures all current and future Okta administrative eventTypes in a single filter.
Note: TOTP-based methods do not generate a dedicated send eventType in the Okta System Log, as the code is computed locally on the user’s device. All MFA outcomes are captured under user.authentication.auth_via_mfa.
Additionally, in the current transformer.json both the What and Where fields are mapped to client.ipAddress, resulting in identical values for every event. For SSO events, target[0].displayName (destination application name) would be a more meaningful value for the Where field.
Reference: Common System Log filters
Currently there is no workaround. The missing eventTypes are simply not collected, resulting in incomplete authentication audit trails. The Where/What duplication is not configurable from the Netwrix Auditor interface.
