NPS with Azure Proxy
Hello,
I’m looking for someone who has tried using Azure Proxy as a RAG.
Is it possible?
Does it still provide the same experience when going through it?
Regards
Hi Romain,
I haven’t tested using an Azure Proxy, however as long as all the components (Portal, Gateway, NPS Server) can communicate per the setup guide then I don’t see how it would cause any issues.
- Dan
Hi,
I think there was a misunderstanding — I’m looking to replace the Portal and Gateway with Azure Proxy.
Is that possible?
I am not aware of anyone who has tried that use case. In theory it’s possible, but I can’t say for sure.
You would need to also proxy 4422 for SSH sessions and 4489 for RDP proxy connections to the NPS application server(s) from the Azure Proxy. I don’t see why it wouldn’t work but also have not set this up nor seen anyone using Azure Proxy.
