Never expire password option for length abiding passwords in Max Age rule
Never expire password option for length abiding passwords in Max Age rule.
In the Max Age rule of a Policy, the highest value we can assign is ‘1825’. Would like to see the option of ‘Never Expire’ for the password meets X amount of characters.
Either not having any passwords expire in the rule (not very effective) or by selecting ‘1825’ days if password meets or exceeds X amount of characters.
Wouldn’t this be handled by just adding the rules “Age (Max)” & “Age (Min)” to the “Disable these rules if a password contains <CHARNUM=1-127> or more characters” in the Passphrases section of Policy Properties?
Potentially, but a better solution is to set “password never expires” for the user. This would also work for Windows policies (some customers use a combination of PPE and Windows policies).
This is currently possible by writing a small script to run after password change (see Netwrix Documentation), but having a GUI option would make it simpler.
Hi, everybody. We will not be implementing the “Never expires” checkbox functionality into the Age (Max) rule not because it would be technically demanding (it wouldn’t), but because it contradicts the established norms when it comes to password security. Even the topmost limit enabled by the Age (Max) rule, which is five years (1825 days), is something that I would most definitely not recommend for anything other than endpoints containing zero confidential data, and even for those I would suggest a yearly password change as the absolute minimum.
From a technical standpoint, the rule can simply not be applied to begin with and if it is to be disabled entirely for passwords above a certain character count, then the Passphrases could be utilized, as mentioned earlier by Kenneth. But this, again, is an irresponsible approach that we cannot endorse. Please note that a longer password provides only some additional security, the advantage which will get completely nullified anyway if the password itself remains unchanged over a long period of time.
