Netwrix Privilege Secure Q1 2026 Release (26.03.0)
This announcement highlights the updates and fixes delivered in Netwrix Privilege Secure version 26.03.0.
Netwrix Privilege Secure Q1 2026 Release (26.03.0) is Now Live!
What’s New
Retention policy
Global setting added for retention time (In days) of:
  • I/O logs (RDP/SSH session recordings)
  • Emails
  • SIEM logs
NOTE: This is deletion not archiving!
User privilege escalation with optional connection to a resource
Some customers want to be able to promote users with NPS, but then go perform tasks outside of NPS and not necessarily have an RDP/SSH session. This feature allows users to select from a list of groups to be promoted into. They may or may not then connect to a resource. When the session ends, the users are removed from groups.
A new activity called “Add User to Groups and Roles” allows the administrator setting it up to select a set of groups and groups (AD, EntraID, Oracle, SQL) and the option, but not required, to select resources
Resource Group Enhancements
Access policies tab to see the access policies assigned to the resource group
Connection profiles tab to see the connection profiles assigned to the resource group
For OU auto-onboarding, set platform
For OU auto-onboarding, set service account (Least Privilege)
Auditor role capability expansion
Auditor role can now monitor live sessions and if needed, terminate or block them
UI filters in User and Resources pages
User Page date range filter for last login
Resources page multi-select filter for operating system
Resources page multi-select filter for resource group
Resources page date range filter for last scanned
RDP Resolution 2k added
2560x1440 resolution added as an RDP choice, though “Full Screen” is probably best choice for most users.
Bug Fixes
ID Description
419689 Linux service account with certificate login tries password first.
419574 User not added to Group if samAccount name differs
419669 Approver emails not sending
423477 Old resources still listed after AD sync
419868 Passwords not rotating on activity start
420690 SQL Server pre-session didn’t add all users to roles/groups
418596 AD sync scheduling fails.
422126 Users nor removed from groups post session
422127 AD resources page “Remove NPS role” button remains after removal
422518 Stop session disables account when used in other sessions
417668 Ephemeral user account profiles not deleted
413805 Logs showing activity time in GMT instead of local time for scheduled activities
415352 Support environments where TLS 1.0 and 1.1 have been disabled (1.2 and 1.3 preferred)
417492 Replay session broke in Safari
403358 Scheduled email report not sending email
Known Issues
ID Description
426243 EntraID password rotation requires password administrator role. Need to update KB.
418597 P12 to PG 16 upgrade requires a manual step for schema update.
Need help with this update?
Situation Action
If you have a question you’d like to ask other experts… Create a discussion in the community: Privilege Secure > Discussions & Questions
If you have a feature request… Let our product team know directly: Privilege Secure > Ideas
If you have something cool to show… Show everyone what you built: Privilege Secure > Show & Tell
What are your thoughts?
This is the release I was waiting for. Thank you, team, for including my feature requests. All the new features are very useful. :clap: :tada:
Privilege escalation was going to be my next request—it’s like you read my mind. :smiling_face_with_three_hearts:
Thank you, looks like a good update! Is there any documentation we can review for the User privilege escalation feature? This article mentions optional connection to a resource - is that a method to avoid the requirement to select a resource when starting an activity? If so, I’d like to know how to set it up. It seems that initial resource selection is dictated by the access policy. Thanks again!
