Netwrix Privilege Secure Q2 2026 Release (26.07.1)
This announcement highlights the updates and fixes delivered in Netwrix Privilege Secure version 26.07.1.
Netwrix Privilege Secure Q2 2026 Release (26.07.1) is Now Live!
What’s New
Localization
French, Italian, German, Spanish, Korean, Chinese (Traditional) options added.
ServiceNow Integration
Connect sessions to ServiceNow for Incident Reports and Change Management. Validate the tickets, auto-updates when sessions are started and ended. Manual notes in NPS added to SN ticket.
.NET 10
Moved from .NET 8 to .NET 10
C++ 14.5
Moved from 14.24 to 14.5
AD differential sync
When doing an AD sync, instead of a full sync, we take advantage of AD’s built-in differential tracking. For large AD instances, this is a large performance boost.
Bug Fixes
ID Description
424937 Can’t find policy which matches: account, resource and activity
438600 Resourceless activity shows 30 minute expiry regardless of actual setting
392759 Provisioning Entra Accounts Error
402118 Old resources still show up in NPS with every AD sync
402925 Passwords not rotating on activity start
403103 Poor performance when filtering resources
420815 Users not getting removed from groups
424095 Slow Server List Loading and Session Creation
432040 SQL Server performance poor
433524 Privileged Accounts not able to RDP into machines
434817 Password not Rotating for multiple users Credential Checkout
434828 New Activities Not Showing in “My Activities”
435018 NPS unable to provision Linux sessions
426953 Account created in all caps will not allow access to Linux resource
426531 Linux sudo elevation failing
436769 Cannot View Historical Dashboard
437957 Cisco Activity Token Provisioning Regression
440585 EntraID - Request_ResourceNotFound
437354 Ephemeral accounts not deleted with AD sync
442697 Events page only shows 30 records with no pagination
426104 SSH failures caused by missing ticket number prompts
435175 Groups don’t show up in Users and Groups
439532 Linux session won’t provision for the accounts that has uppercase letters
440181 Login not possible after updating
437949 Multiple password changes simulatenously for user, wrong password being returned
438776 No connection to Linux systems
405323 Not able to scan Windows host using IP address
436011 Password is "empty when copied or Error 404 when clicked on view password
445877 PlatformId Null without scan
443492 Schedule task getting queued and not finishing
440664 Unable to recreate service account after it is deleted
447423 SRA portal fail
447467 Unable to provision Cisco devices that support both secret and password for users
447582 Host collision insert error
Known Issues
Description
EntraID password rotation. Microsoft tightened permissions and requires additional roles. See the setup instructions for details.
EntraID 404 issue - First off, ensure that the Entra service account has the proper permissions (see link above) Second, most EntraID issues were resolved in 26.03.2. However, a customer with a version of NPS prior to 26.03.2 may have an EntraID account that still won’t work. It must be deleted and then re-scanned into NPS to work. Since the NPS soft-deletes accounts, it may have to be removed from the database. Support may be required to do this.
P12 to PG 16 upgrade sometimes requires a manual step for schema update using the DBUpater tool.
Weak SSH algorithms. The SSH algorithms NPS uses may be modified to comply with customer security requirements (usually removing “weak” algorithms). Be sure both files are present and modified. See the configuration guide.
Microsoft KB5082142 includes deprecating the RC4 algorithm for Kerberos tickets. Domain controllers with the patch stop issuing RC4 tickets. Microsoft tried to make this seamless, but there could always be accounts that don’t get updated or can’t accept RC4. See this article for details on the change, or this one if you’re troubleshooting authentication failures.
AD Sync scheduling offset one hour. This bug was fixed, but if upgrading from a release where the AD sync was one hour behind when it is scheduled, then it has to be reset. Set the schedule to none, save, then set to the proper time and save again.
PlatformID issue. When upgrading from previous version to 25.12.0 and up to this release, resources needed to be re-scanned to bring in a new platformID. This caused issues for customers that didn’t know to rescan and in some cases even caused issues for customers that did know. In this release, we put in a fix so that the resources rescan automatically and fixes the platformID issue. However, in a very specific case, upgrading from 25.12.1 and NPS is in a cluster environment, then a rescan is still required. We don’t see this issue for stand-alone server installations or other upgrades.
Null DNS or duplicate Resources:
Before upgrading to this release, check the resources list. If there are any resources with DNS, then they should be removed before upgrading. Once upgraded, re-onboard and scan them.
If they are not deleted, then after the upgrade, then those resources will show up as duplicates with the same IP address. If this happens both entries need to be deleted and the resource re-onboarded and scanned.
Need help with this update?
Situation Action
If you have a question you’d like to ask other experts… Create a discussion in the community: Privilege Secure > Discussions & Questions
If you have a feature request… Let our product team know directly: Privilege Secure > Ideas
If you have something cool to show… Show everyone what you built: Privilege Secure > Show & Tell
What are your thoughts?
I upgraded NPS from the Q2 2025 release to 26.07.1 and ran into an issue where it deleted the SAML request and signout template .xml files, which in turn caused SSO logins to fail until we restored those files from a backup. Netwrix Support was very helpful in assisting me with getting that resolved and mentioned that this was apparently a known issue that can happen with this upgrade. I do feel like it should be called out specifically in the upgrade documentation to backup those files prior to upgrade. It would save other customers a potential outage and hassle with opening up a ticket. Thank you.
Thank you for that feedback Jason! It’s much appreciated.
Appreciate you mentioning this as I just ran into this issue on the update as well. I was able to quickly get the template files restored and SSO working again thanks to your mention. Really surprised this isn’t updated in the known issues section of this post for clearer visibility.
Are there any separate release notes for the Netwrix Secure Remote Access v 26.07.1 release and any (public) update instructions? So far the Netwrix support could not provide them and recommended to me not to update the RAG/SRA to version 26.07.1.
Hello Jason
is there any chance that you can share the filename and path of those template files?
That would be greatly appreciated.
I’m struggling with a similar issue where SAML authentication using AdSelfService Plus broke since the update.
thanks
Hello Dany,
The file location for the SAML templates is X:/Program Files\Stealthbits\PAM\Web\. In this location, you can drop in or replace SamlRequestTemplate.xml and SamlSignoutTemplate.xml.
I have attached those template files to this reply.
If you have any questions about the process, please contact support.
SamlSignoutTemplate.xml (410 Bytes)
SamlRequestTemplate.xml (495 Bytes)
Was this issue specific to SAML, or did it impact other SSO authentication methods, as well? (OIDC, etc)
We had it effect Entra SSO as well. We had backed up the SAML files beforehand though and copying them back fixed it.
Wondering if others are seeing issues with the Users & Groups tab? When we pull it up after upgrading, the page just spins. Dev tools show https://***/api/v1/ManagedAccount/Search?skip=0&take=30 returning a 500 status code, and I have a script calling this same API and also getting the 500 status code.
We have only seen this happen to the SAML templates, but it may be present elsewhere.
Hello Greg,
Thank you for your Community post. We have a fix for this. It involves resolving a lockout in the database. If you open a support ticket we can help you apply this. A fix included in a release is also being developed.
I can confirm that we did not see this issue with our OIDC authentication.
