Native Box Drive application support
Box is retiring Box Sync and replacing with Box Drive and it would be good if native application on Mac OS and Windows be supported.
I believe we are not the only company using Box cloud solution which faces the same issue that Box drive is not being supported by Netwrix End Point Protector.
Only way to solve it now is to disable Box Drive on Box end and not use it at all, using web interface instead, which is far from optimal.
Hello Sarunas,
Welcome to the Netwrix Community!
I’m delighted to share promising news here! The implementation of native Box Drive for Windows and macOS is already planned on our roadmap and as development progresses successfully, we are committed to keeping you informed with updates regarding the delivery timeline.
Stay tuned!
Thank you for your insightful suggestion!
Regards,
Simona
Great news indeed, thank you.
Hello Sarunas,
We’re excited to share that enhanced visibility for the native Box Sync app on Windows and macOS is now available! This improvement is included in the latest Netwrix Endpoint Protector 2511 Client & Enforced Encryption Release.
You can read the full release announcement here: https://community.netwrix.com/t/endpoint-protector-2511-client-enforced-encryption-released/117986
We hope this will bring you great value.
Kind Regards,
Simona
