The following parameter are missing in the Output of --help
--out <filename>writes output to file instead of console. combination with--log-consolewrites detailed log into that file as well.--license <LicenseAsBase64>define a license to use in current run only--debug-licenseshow license information for used license
There are more missing in the --help, but I am currently using these and was wondering if they will keep doing what they do in future versions and why they were not added to the help.
