Identity Recovery Bug Fix List
:pushpin: Looking for a bug fix list for all versions of Identity Recovery?
All bug fixes will automatically be added here!
3.1 Updates
Identity Recovery Version 3.1.5.30 Released
August 6, 2026
  • Added support for backing up US Government Entra tenants, which require connecting to a dedicated Gov cloud endpoint URL.
Identity Recovery 3.1.4.9 Patch Version Released
May 5, 2026
  • Resolved a limitation that prevented selection of a preferred domain controller during Active Directory object backup operations (internal work item #397731)
  • Resolved missing msoledb driver and C++ runtime dependencies from the installer package (internal work item #435122)
Identity Recovery 3.1.3.2 Patch Version Released
April 28, 2026
Entra ID restore
  • Fixed an error that prevented deleted Entra objects from being restored when using the “Use latest Entra properties” option
Identity Recovery 3.1.2.26 Patch Version Released
March 31, 2026
Additional Entra object support (case 420768)
  • Conditional access policies and directory roles support added
Dashboard Widget Modularity and Customization (case 418233)
  • Dashboard widgets now show a user-friendly message when the linked module is not configured
  • Dashboards widgets can now be hidden if they are not applicable to the customers usage
Product install in an air-gapped environment (case 415257)
  • Bundled the required NET 10 framework in the installer to allow for successful install in all environments
Identity Recovery Patch Version 3.1.1.4 Released
February 10, 2026
  • #406580, #406581: Fixed paging and throttling issues when retrieving Okta collections.
  • #415257: Resolved an issue that prevented the product from being installed in air-gapped environments.
Identity Recovery 3.1 (formerly Recovery for AD) Released
January 15, 2026
Version Bug Resolution
3.0.2.9 398970 Resolved an issue where Domain Controller Backups enumeration did not return all available backups.
3.0.1.22 398056 Fixed an issue where SMTP Notification Settings were not saving correctly.
394744 Addressed a bug where the SMTP module was not registered successfully.
398964 Entra ID settings are now fully validated when creating or editing configurations.
397501 Corrected an issue where modifying Entra ID job schedules resulted in unexpected triggers.
397656 Entra ID enumeration no longer hangs when object display names begin with a space.
397066 The Dashboard layout is now saved correctly between user sessions.
3.0 Updates
Patch Version 3.0.2.9 Released
September 11, 2025
Bug ID Escalation Fix
398970 453793 Resolved an issue where Domain Controller Backups enumeration did not return all available backups. Enumeration now displays the full set of backups as expected.
Patch Version 3.0.1.22 Released
August 28, 2025
  • Bug 398056 Recovery for AD 3.0 SMTP Notification Settings Not Saving, escalation 453033
  • Bug 394744 SMTP module not registered successfully
  • Bug 398964 Entra settings are not fully validated when creating or editing configurations
  • Bug 397501 Schedule modification of Entra jobs results in unexpected schedule triggers
  • Bug 397656 Entra enumeration hangs when object display names begin with a space
  • Bug 397066 Dashboard layout is not saved between sessions
Version 3.0 Released
July 24, 2025
No bugs were fixed in this update.
2.6 Updates
Version 2.6 - Release Notes & Bug Fixes
September 17, 2024
See the Netwrix Recovery for Active Directory v2.6 Bug Fix List for a list of bugs fixed in this version.
:double_exclamation_mark: The following versions may have limited or no support. Please see the Supported Version page for guidance.
2.5 Updates
Version 2.5 - Release Notes & Bug Fixes
December 13, 2022
See the Recovery for Active Directory v2.5 Bug Fix List for a list of bugs fixed in this version.
