Have access to a report or dashboard that identifies devices connected for the first time to protected computers within a selected time period (day/week/month/etc.).
Visibility into newly introduced devices in the environment is needed to support security monitoring, auditing, and compliance use cases. Currently, Device Control only provides a cumulative list of all devices ever connected (List of Devices) and a Logs Report with events related to devices connected to protected computers (Connected, Blocked, Unblocked, Disconnected, etc.), but neither can be filtered to isolate first-time connections within a defined timeframe.
This creates a gap in identifying newly used or potentially unauthorized devices. A dedicated report or dashboard that highlights devices whose first recorded connection falls within a selected period would solve this problem efficiently. Ideally, this feature would include filtering options (time range, device type, computer, user) and could be visualized in a dashboard widget and exportable report.
This approach removes the need for manual comparison and provides immediate, actionable insight into new device activity, improving both operational efficiency and security posture.
Currently, EPP admins must export the full device inventory (List of Devices) at two different points in time (e.g., today vs. last week/month) and manually compare the datasets to identify newly connected devices. This process is time-consuming, error-prone, and not scalable.
