Extend logging to mention servers and services wich could not be reached
Optimize logging so that has a summary of failed targets/ports/services
As mentioned in the discussion “WMI hotfix detection failed” ( WMI hotfix detection failed / Access denied when querying Win32_QuickFixEngineering ) the log and the results (html/xml) should mention in a summary that some queries could not be done and the results could have more results.
Here an example how the result could look like
Some targets could not be reached. The report may not include some risks or have missing details. Validate the following table:
source target targetname protocol port servicename reason
192.168.0.100 172.16.254.100 EU-DC-12 tcp 139 rpc syn-sent-timeout
192.168.0.100 172.16.254.100 EU-DC-12 tcp 389 ldap syn-sent-timeout
192.168.0.100 172.16.254.101 EU-DC-13 tcp 389 ldap syn-sent-timeout
192.168.0.100 172.16.254.101 EU-DC-13 tcp 636 ldap syn-sent-timeout
192.168.0.100 172.16.254.102 EU-DC-15 tcp 636 ldap unexpected response
192.168.0.100 172.16.254.102 EU-DC-16 tcp 636 ldap tcp-reject
192.168.0.100 172.16.254.101 EU-DC-13 udp 56891 rpc no response
192.168.0.100 172.16.50.50 EU-WSUS-02 tcp 8531 WSUS syn-sent-timeout
Would be great to have information like that in the XML as well.
manually searching for any errors in the log, analyzing it, find out which port is used
or:
monitoring tcp sessions for connections wich are in “syn-sent” state for a while with cmd netstat -noa | find "SYN"or PowerShell with while (1) {Get-NetTCPConnection -State SynSent -ErrorAction SilentlyContinue -OwningProcess $((Get-Process pingcastle).id);Start-Sleep -Milliseconds 500} (abort with CTRL+C - just made that tiny script for this post) or checking firewall logs depending on customer.
If a “SynSent” with equal source:port and target:port is seen more then once then I can assume there was no response within 500ms and the port might be closed or the server/service is not available.
As I use PingCastle in different customer environments as an auditor, I don’t always know what the customer has and some Admins don’t know / can’t see what policies really are in their firewalls.
Afterwards, I generate a list of closed ports to discuss with the customer whether this behavior is intentional.
I am looking into this. Migration to CIM Instance with fallback to WMI.
We will also expand the KBs as they are currently insufficient as they do not take into account the cumulative updates. We will implement both a hardcoded check for 2016 and a dynamic one for potential recent installations which will check for new updated installations.
We will add some better logging and outputs for this so it is clear what has happened.
I will reply when I have more info and may be able to share a beta build or some screenshots.
