Data Classification Bug Fix List
:pushpin: Looking for a bug fix list for all versions of Data Classification?
All bug fixes will automatically be added here!
5.8 Updates
Netwrix Data Classification v5.8.0.11 — Release Notes
October 5, 2026
Improvements
  • Added a configurable maximum size for report subscriptions
  • Improved queue processing and reporting performance on large databases
Bug Fixes
  • Fixed pending SQL deletes timing out when many items are deleted
  • Fixed the Apply MIP Label workflow action overwriting existing sensitivity labels
  • Fixed MIP label operations failing for DoD and GCC High tenants
  • Fixed an issue where sources could not be resumed after upgrading to version due to a database query error.
  • Fixed an issue where graph sources would hang when attempting to save configuration changes.
Security & Dependencies
  • Updated the bundled Java runtime (OpenJDK JRE) to version 17.0.20.1
  • Updated Apache Log4j in the bundled Apache Tika extractor to version 2.25.5
  • Updated the bundled Tesseract OCR engine to version 5.5.3, which includes libcurl 8.21.0
  • Updated the Microsoft Information Protection (MIP) SDK to version 1.18.148, which includes OpenSSL 3.5.7
Netwrix Data Classification v5.8.0.7 — Release Notes
September 30, 2026
Improvements
Bug Fixes
  • Includes routine security dependency updates with no impact to functionality or compatibility.
7.11 Updates
Netwrix Data Classification v5.7.11.8 — Release Notes
July 14, 2026
Server — v5.7.11.8
  • OpenJDK updated to version 17.0.19+10
  • log4j updated to version 2.25.4
Netwrix Data Classification v5.7.11.1 — Release Notes
July 6, 2026
Server
  • Restored column sorting on the Sources grid and Invalid File Types table (#431459)
  • Added scheduled automatic expunging of deleted file records (#395669)
  • Converted database columns to support Unicode characters (#432488)
  • Fixed workflow wizard incorrectly displaying a validation error after removing any condition (#338923)
  • Added support for passwords up to 256 characters (#417539)
  • Updated Credentials taxonomy to match password-related terms case-insensitively (#424055)
  • Fixed required terms extraction generating incorrect multi-word terms (#371480)
  • Fixed semi-colons being incorrectly stripped from metadata values (#425302)
  • Clarified MIP sensitivity label configuration options for GCC High and DoD environments (#437146)
  • Fixed errors occurring when the server is configured for FIPS compliance (#435561)
  • Fixed Duplicate Detection report returning false positives in file exact-match mode (#436005)
  • Fixed report subscription emails failing when no username is configured for the mail server (#418593)
Connectors
  • Fixed SharePoint crawl error when item permission assignments are uninitialized (#411696)
5.7 Updates
Netwrix Data Classification 5.7.12.1 — Release Notes
September 17, 2026
No bugs were fixed in this update.
Netwrix Data Classification v5.7.11.17 — Release Notes
August 11, 2026
  • Fixed SharePoint list items permanently failing collection due to an uninitialized property error
  • Fixed redaction failing to match regex metadata values due to trailing semicolons
June 29, 2026
Server — v5.7.11.8
Netwrix Data Classification v5.7.11 — Release Notes
June 11, 2026
Server
Connectors
Netwrix Data Classification 5.7.10.15 - Rebranded UI
February 5, 2026
Netwrix Data Classification 5.7.10.1 Released
December 16, 2025
Bug fixes for Netwrix Data Classification
July 29, 2025
Netwrix Data Classification 5.7.9.1
Description Case #
Fixed intermittent decryption failure during recollection. 348233
Added support for MIP labelling in GCC environments 385511
Fixed memory leak in classifier. 385909
Updated packages to latest version: System.Text.Json > 6.0.10 / SevenZipExtractor > 1.0.19 / Updated JDK to 17.0.14. 383384
Netwrix Data Classification 5.7.8.1
Decription Case #
Added support for filtering on files without extensions. 361900
Ignoring files based on metadata now works on all metadata fields. 372095
Query performance improvements. 358743
SharePoint – Sensitivity column is now updated when MIP label is set on PDF files. 372691
Fixed UI issue with time selector for suspended services. 365938
Netwrix Data Classification 5.7.7.1
Description Case #
Resolved issue with crawling SQL Server with hierarchy_id columns. 367779
SQL crawling now limits number of active threads applied to a server to the Domain Collector Threads configuration value. 311824
Netwrix Data Classification 5.7.6.2
Description Case #
Upgraded Tika OCR engine to latest version. 356034
Improved handling when expunging large numbers of documents. 345673
Added ability to convert PDFs to images before OCR process to improve text extraction. 362440
Workflow: Creation of stub files now uses credentials from the target source. 344523
Files Skipped report now supports filtering by file extension. 361900
Resolved issue when redacting documents that contain multiple subsets of redaction criteria. 350727
Resolved issue passing empty strings into PDF Keywords field. 365265
Minor Version 5.7 Released
February 14, 2023
See the Netwrix Data Classification v5.7 Bug Fix List PDF for a list of bugs fixed in this version.
5.6 Updates
Minor Version 5.6.2 Released
March 1, 2022
See the Netwrix Data Classification v5.6.2 Bug Fix List PDF for a list of bugs fixed in this version.
