Netwrix Data Classification 5.7.9.1
Description
Case #
Fixed intermittent decryption failure during recollection.
348233
Added support for MIP labelling in GCC environments
385511
Fixed memory leak in classifier.
385909
Updated packages to latest version: System.Text.Json > 6.0.10 / SevenZipExtractor > 1.0.19 / Updated JDK to 17.0.14.
383384
Netwrix Data Classification 5.7.8.1
Decription
Case #
Added support for filtering on files without extensions.
361900
Ignoring files based on metadata now works on all metadata fields.
372095
Query performance improvements.
358743
SharePoint – Sensitivity column is now updated when MIP label is set on PDF files.
372691
Fixed UI issue with time selector for suspended services.
365938
Netwrix Data Classification 5.7.7.1
Description
Case #
Resolved issue with crawling SQL Server with hierarchy_id columns.
367779
SQL crawling now limits number of active threads applied to a server to the Domain Collector Threads configuration value.
311824
Netwrix Data Classification 5.7.6.2
Description
Case #
Upgraded Tika OCR engine to latest version.
356034
Improved handling when expunging large numbers of documents.
345673
Added ability to convert PDFs to images before OCR process to improve text extraction.
362440
Workflow: Creation of stub files now uses credentials from the target source.
344523
Files Skipped report now supports filtering by file extension.
361900
Resolved issue when redacting documents that contain multiple subsets of redaction criteria.
350727
Resolved issue passing empty strings into PDF Keywords field.
365265
Need help with this update?
What are your thoughts?
rohair84
(Ralph O'Hair)
September 4, 2025, 12:33pm
2
I noticed this morning that the release notes in product downloads for 5.7.9.1 do not contain the up-to-date information listed in this post, but instead only include up to 5.7.5.3 in the 2023-2024 Netwrix Data Classification v5.7 Bug Fix List.
dimav
(Dmitry Vorontsov)
September 22, 2025, 4:27pm
3
Hi Ralph, do you imply the link here? We have just fixed that one. Thank you for bringing this to our attention!
